Ok i have replaced the starter on my Generac Guardan 15,000 watt MODEL:004582-2 there were 4 wires on the starter one blue slip on wire and two small blue wires marked 13 and a red battery cable i goofed and took off the starter wires about november and forgot what wires go were i have the slide on wire in the right spot, but not sure where on the starter the red battery wire gos toand were the two blue wires marked 13 go I hope you can help me
Https://www.partstree.com/parts/generac-power/portable-generators/0045822-generac-guardian-15-000-watt-portable-generator-sn-4
Found this wiring diagram. see if this will help you.
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
SOURCE: ok, here is a list of the factory wires coming
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Testimonial: "thank you greatly. that does help alot."
SOURCE: what wire gos on right side small terminal of
facing the front of the starter, the terminal closest to the engine is the trigger wire for the solenoid. any other small wires would generally be attached to the other small terminal if yours has one. (trigger wire is the only small one that will have full 12v with key turned to start position)
SOURCE: Generac control wires
older model Generac only haver 4 control wires:
N1
N2
23
194
if it is the included wiring harness the wires should have their numbers stamped on the jacketing and a sticker should designate the proper screw to mount it to in both the ATS and the generator housing. hooking these wires up incorrectly often results in blown fuses and/or damage to the control board in the generator.
