it sounds like the thermostat on the rinse tank is set too high, if you drop the panel on the bottom front of the dishwasher,you will see the rinse tank, usually on the l/h side,its normally a cylindrical shape,the hermostat is normally connected to this, usually there is an adjustable shaft on the stat, it might have numerical markings on it i.e 0 to 90 degs . MAKE SURE THE POWER IS OFF TO THE UNIT !!, THIS IS CRITICAL FOR TOUR SAFETY!!. if your unsure get a proffesional to repair it . shouldnt be too expensive , hope this helps .p.s if you do have a go the rinse temp should be between 75 and 85 degrees c .
220 degrees is normal operaing temperature for your car. The thermostat does not open until 195 degrees and the fans don't come on until 126 to 128 degrees. If it gets over 129 degrees and the fans have not turned on then the cooling fan system is the cause of the problem. (cooling fan, cooling fan temp switch, cooling fan relay, etc.)
I don't see the date when you posted this problem but it is still on unsolved suport section. So I try to let you know that all Champion dishwashers need the first inital start up . That is make sure water is in the booster , Locate the Installation and service toggle switch on the extreme left side of the control box.Prime the booster .
Let me know if you still want more information about this unit. God Bless,
The wash tank heating element is control by 1. the dual Float switch 2. The temperature control 3. the high limit thermostat 4. Contactor 5. tank heat fuse 6 element itself. Hope this help. God Bless.
if you turn the unit off from the circuit breaker will the water still run?if so the guts inside the solenoid valve are worn.you can call champion and get a kit to replace the worn parts and its not difficult to do.hope this helps.
