20 Most Recent Champion UH-100B 40 Commercial Undercounter Dishwasher Questions & Answers
it sounds like the thermostat on the rinse tank is set too high, if you drop the panel on the bottom front of the dishwasher,you will see the rinse tank, usually on the l/h side,its normally a cylindrical shape,the hermostat is normally connected to this, usually there is an adjustable shaft on the stat, it might have numerical markings on it i.e 0 to 90 degs . MAKE SURE THE POWER IS OFF TO THE UNIT !!, THIS IS CRITICAL FOR TOUR SAFETY!!. if your unsure get a proffesional to repair it . shouldnt be too expensive , hope this helps .p.s if you do have a go the rinse temp should be between 75 and 85 degrees c .
Champion UH-100B... | Answered on Dec 06, 2012
Check the element for continuity, on some dishwashers, it will cycle until correct temps are reached
Champion... | Answered on Apr 04, 2019
Try going into the settings
Champion... | Answered on Mar 10, 2017
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Champion... | Answered on Jul 13, 2010
do not use nocommercial dish washer powder, it may ruin ur recirculating sump pump, alwasy us manufacture recomendation, or you will void the warranty
Champion... | Answered on Sep 12, 2009
Manual below, In troubleshooting it only shows P1, P2 & P3 contact dealer. You may find other info which may help
https://www.partstown.ca/modelManual/HOB-AM15T_spm.pdf
https://www.manualslib.com/manual/612400/Hobart-Service-Am15.html
This manual below is for several Hobart models and troubleshooting say check with Hobart service or water level probe in holding tank or refer to leaking valve in troubleshooting.
https://cdn2.webdamdb.com/md_1eYg2WvadTUF.jpg.pdf?1475613791
The link below has some ideas and suggestion dealing with water in the machine
https://hvac-talk.com/vbb/showthread.php?1560581-Hobart-AM15-T-wash-temperature-problem
Dishwashers | Answered 4 hours ago
HE WHO? WHAT DISHWASHER?
Dishwashers | Answered 5 hours ago
You didn't mention what brand dishwaser you are talking about, but if it is a Bosch, they are known for having the impeller (which is in 2 parts) coming apart, so the part of the impeller that has the blades doesn't turn. In other dishwashers, I've seen the holes in the wash arms get clogged, especially if you don't have the removable filter installed correctly, or (if it's a GE), the filter plate on the bottom gets warped, allowing bood and debris to get in the wash arms and clog up the holes. We really need to know the brand and model number of the dishwasher (or any appliance) to be able to help you accurately.
For the manual, try Googling (Hisense)(h12dme)(manual) without parens.
Dishwashers | Answered 8 hours ago
talk with a doctor about the problem
one indication is bones that break easily and that is only evident on breaking a bone from a minor incident
doctors can do a bone density test and that will indicate a problem
remedy is simple but talk with your doctor
Dishwashers | Answered 2 days ago
Champion UH-100B 40 Commercial Undercounter Dishwasher Logo
2 questions posted
Top Champion Dishwashers Experts
Jude24
Trevor Turner
Gareth Morling
Level 1 Expert
Are you a Champion Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Champion Dishwashers
Most Popular Question
dishwasher running hot
  • Dishwashers
