I can't say for sure, but I have an KDL 46XBR5 and it may be similar to the 52". The stand is most likely being held in place beneath the back cover like the unit I have.
After you unplug the tv, lay it on a flat surface with a very soft clean blanket so you don't scratch it up. Place the television face down with the stand facing you.
Now if you look very closely, you may see little arrows (they look like this : -->) and little triangles all over the place. Disregard the triangles altogether, but remove all of the screws that have little arrows (again, they are the ones with he "->" pointing to the screw. There could be anywhere from 16 to 24 screws.
Make sure you put them back exactly where they came, there are usually different sizes). A piece of cardboard with a rough diagram drawn with marker helps, just push the screws into the cardboard where they line up on the tv.
Once you remove the back cover, you will see the stand has two large brackets screwed into the back of the television. They are vertical from the bottom.
I have attached diagrams showing the removal of the back panel as well as the bracket for my KDL46XBR5. YOURS MIGHT LOOK DIFFERENT but should be somewhat similar or at least give you an idea to go by
Note: If I am not mistaken, there are two black insulated copper ground wires connected to the bracket. If you disconnect the brackets, you will need to figure out where to reconnect these ground wires most likely or remove them altogether.
Hope this helps
In the back of the TV just above the stand, there is a recession in the back panel. In there you will find 4 large screws in a trapezoidal pattern that are holding the stand. The two top screws are closer together than the two bottom screws. You can also tell that they are not touching the back cover and are mounted directly into a steel plate. Simply remove these and then slide the stand out.
SOURCE: Cannot remove tv guide banner from Sony bravia 52'
Click on the display button (upper left corner) as a short term fix - it will turn it off immediately - not sure of how to permanently solve this though.
SOURCE: how do I remove the stand of the Sony Bravia XBR
you have to lay the tv on it's front on something to protect it from being damaged.on the back you'll see where the base joins the bottom of the display, this needs to be unscrewed and a wall bracket screwed in instead.
SOURCE: How to remove the table top stand for wall mounting?
Take all the screws out of the base,might require an Alan wrench.Take mellet make a couple taps.Should pull the base right out.
SOURCE: I have a small green vetical line in my sony
Unplug the TV , the hard reboot will cause the line to disappear in a few minutes, must be some algorithm that kicks in
