Kodak Easyshare M580 Digital Camera Logo
Posted on Mar 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What kind of battery can I buy for my M580 Kodak easy share?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Kodak Master 102,366 Answers
  • Posted on Mar 24, 2013
Kodak Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444639
Points
622693
The M580 uses the KLIC-7006 or equivalent. Two sources are here and here.
5 Related Answers
otacon
Damen Wong
  • 1950 Answers
  • Posted on Mar 05, 2008
SOURCE: hOW USE KODAK EASYSHARE C330 AS WEB CAM
I am sorry but you can't use your camera as a webcam.
Anonymous
  • Posted on Dec 20, 2008
SOURCE: my kodak easy share Z1275 won't come on
mine has the same problem, but if i take of the batteries and put them back again, it works until i turn it off, then if i want to turn it back on again, i have to take the batteries off again... try it
Anonymous
  • Posted on Jan 19, 2010
SOURCE: kodak easy share v1003 with broken lcd how i can fix this cheap
Sirs I have a Kodak easy share v1003 showing the screen completely white. How can I replace it... seems that I already find the spare part in e-bay. Can I do this replacement by mayself?
Anonymous
  • Posted on Apr 12, 2010
SOURCE: Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
Anonymous
  • 141 Answers
  • Posted on Apr 22, 2010
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
2answers
Will not charge
Kodak camera wont charge? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 1, 2011 - My Kodak EasyShare M580 digital camera wont charge. I have the USB charger, but when I plug everything in, the charging light wont light up, ... Kodak Easyshare camera will not charge?
Mar 27, 2014
My kodak easyshare m580 WILL NOT charge?
Mar 14, 2012
Kodak Easyshare M580 Not Responding To Charger?
Dec 7, 2011
My kodak easyshare m580 will not charge?
Apr 16, 2011
More results from answers.yahoo.com
Replaced battery since it wasn't holding a charge. Has been plugged in for 24 hrs, still won't power on when unplugged from wall charger. What course of action should I attempt?
Possibly the charger itself is bad and only operating as a electrical connection/power cord for your camera. Try borrowing or buying another charger or take the camera to a local camera repair center or Best Buy, etc or contact customer service for your camera's manufacturer.
Hope this helps. Mike
1helpful
What cable do I need to buy so I can connect my Kodak M580 Easyshare to either my laptop or my desktop computer
You don't need a cable. As I explained in my answer to your earlier question, you'll be much better off with a card reader, if you don't already have one on your computer.
I need a manual for the kodak easy share M580
user guide:
http://support.en.kodak.com/app/answers/detail/a_id/19302/kw/m580
extended user guide:
http://support.en.kodak.com/app/answers/detail/a_id/19299/kw/m580
Jun 20, 2011 • Cameras
Kodak M580 manualI I need a mamual ,to learn more about my M580. ser.# KCTMT02720751 [email protected]
user guide:
I purchased the Easy Share M580 Digital Camera with the battery charger for the KLIC-7006 battery-also included. I am taking a trip to Europe starting in Stockholm, Sweden - cruising the Baltic Sea to...
The charger should be 110 v ~ 220 v (it should be in the fine print on the charger itself). If it includes 220 v then you will not need a converter. If it only states 110 v, without stating 220v, then you will need a converter. In either case, you should have no issue finding the adapter or the converter in any ma and pa hardware store after arriving to the country you're visiting.
The battery life depends on the amount you're using the camera. It should last you a few days each full recharge.
1helpful
I just want to know what battery to buy for a Kodak M763 Easy share digital camera
This is the battery that you need to buy its a Kodak KLIC-7001 Lithium-Ion
Apr 24, 2009 • Cameras
1helpful
Kodak Easy Share CD1013 pictures won't download on Vista
Hello and welcome to FixYa
Please go to a electronics store and buy a USB card reader. I bought one last week and it cost $0.5 so its cheap as dirt. Then simply remove the card from your camera , pop it into the reader and the pictures will appear on a drive like a flashdrive in your my computer folder.
This is a much better option than using the camera's cable as it is faster , safer , saves on your camera battery and you don't need to install any software or drivers.
The card reader will most likely also still be compatible with any new camera you buy in future.
Kind Regards
Andrea
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
