Around this shop we diagnose, and not assume.
1) Test the AC adapter (Charger)
Test with a multimeter set to DC Voltage. You should read VERY close to 19 Volts. (DC)
While testing have an assistant gently wiggle the power cord TO the AC adapter, and the power cable coming FROM the AC adapter.
See if there is an intermittent reading for either one. Indicates a break in the wire/s.
2) AC adapter checks out OK go to the DC Power Jack. This jack is the port on the side of the laptop, that the AC adapter plugs into.
(DC IN)
Remove the Battery, see if you can gently wiggle the Center Pin. Use a non-metallic object, or tool.
Also check if the metal shell inside the DC Power Jack moves around.
ANY perceptible movement indicates a problem with the DC Power Jack.
Fortunately, for this model the DC Power Jack is a Power Jack Harness,
http://www.lapdiy.com/toshiba-satellite-l305s5941-power-jack-wire-port-dc-in-cable-p-7556.htmlThe jack portion is a squarish shape with a channel formed around it, and sits in a cutout formed in the outside edge, of the Lower Case.
The harness coming from the jack has a plug on the end.
You just unplug it, and plug a new one back in.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L305-L305D/big/remove-lcd-screen-replace-video-cable-09.jpg
In the photo above, it shows a Toshiba Satellite L305 series Notebook PC, partially disassembled.
On the right side you see the optical drive. Squarish shaped with one corner gone. Has a large white label on it, with a smaller yellow rectangular label.
To the upper right you can barely make out a Red wire. It is connected to the black DC Power Jack.
Looking straight across from it to the Left, you see the other end of the Red wire connected to a white plug.
That's the DC Power Harness, and where it plugs in.
This is the entire article,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L305-L305D/remove-screen-replace-video-cable-2.htm(Page 2, and 3 is listed at the top, and bottom of the page, in white.
Page1::Page2::Page3::Find another model )
Posted to show the DC Power Harness, and a pictorial guide that I feel will help get you started.
3) Power Button Board:
Has the Power On switch on it,
http://www.laptoppartsexpert.com/i-7600699-power-button-board.htmlIf the Power On switch is working, the laptop isn't going to turn on.
('Natch)
See the two wires coming from the board? Black and Red?
Red is the Positive wire, Black is the Negative wire.
Unplug the Power Button Board's plug to the motherboard. There are 2 pins. Carefully touch a small flat tipped screwdriver, (Jewelers is recommended), BRIEFLY to these 2 pins.
Laptop comes on you have a bad Power Button Board.
4) If none of the above is the problem you have a bad power sensor chip.
It's a Power MOSFET.
http://en.wikipedia.org/wiki/Power_MOSFETSoldered to the motherboard, and takes skill to replace.
(It's a power transistor that is used in the circuit.
Need to use Heatsinks on the J type leads when replacing, and good skills for un-soldering/soldering.
But doesn't take a rocket scientist to replace it.
{ Sorry Gort }
This example is used in a LOT of laptops,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg )
Or replace the motherboard.
For additional questions or comments, please post in a Comment.
Regards,
joecoolvette
(Link to free Service Manual to be included in a Comment )
