20 Most Recent Dell Inspiron N5030 Notebook PC Questions & Answers
If you have a new Dell computer and it has a service tag on it, contact Dell, let them know your tag number, and they will help you.
Dell Inspiron... | Answered on Nov 29, 2017
run it without the battery just mains if runs ok it a faulty battery
Dell Inspiron... | Answered on Aug 30, 2017
The screws are on the bottom of the laptop that hold the plamrest to the base. Just tighten all the screws on the bottom and see if it helps.
Dell Inspiron... | Answered on Aug 14, 2016
replace the battery
Dell Inspiron... | Answered on Mar 29, 2015
you may have to replace the speakers or wrap the audio wires with Mu-metal foil.
Dell Inspiron... | Answered on Feb 11, 2015
This is common. Win7 does this for some reason.
Download the WiFi and LAN drivers, save them to a USB stick then install them on the Dell.
Always use drivers from Dell!
Dell Inspiron... | Answered on Aug 16, 2014
There could be a multitude of problems. The most basic would be that you do not have the password. If that is not the issue, then test another wireless device, if that is working, then the problem is in your laptop having the issue connecting. At this point connect an ethernet cable to the laptop and see if that works, if so it is your network card, if not then it is most likely a driver issue.
Dell Inspiron... | Answered on Aug 15, 2014
emm, forgot Windows 7 password?
There are some methods for you to reset it, just follow the info and have a try
Option 1: Use a password reset disk to reset lost password if you have created one before forgtting the password.
requirement: USB flash drive or floppy
time: a few minutes
Note: This password reset disk can be only created when you can log on with the lost windows password.
Option 2: use a freeware to crack lost windows admin password, then you can get back the password, like Ophcrack
requirement: download Ophcrack live cd,
time: more than i hour
Option 3; a high efficient and easy-to-use low affordable shareware, like Windows Password Recovery Tool, which can reset windows 7 password quickly and successfully.
Requirement: a bootable CD/DVD or USB flash drive.
Time: within a few minutes.
Visit http://www.windowspasswordsrecovery.com
Step 1: Download and install Windows Password Recovery Tool in any available computer.
Step 2: Burn a bootable CD/DVD to remove lost Windows password. (or USB Flash drive)
Step 3: BIOS settings
Step 4: Recover forgotten Windows password with the burned CD/DVD (or USB Flash drive)
good luck ~
Dell Inspiron... | Answered on Jul 15, 2014
Not all webcams are great quality, and can appear fuzzy, especially in low light. Was the webcam previously producing a better image?
Dell Inspiron... | Answered on Jan 31, 2014
There may be finger prints on the lens.
Some how you lost the Operating System Boot Sector. If you had full function prior to this message notification; then a virus, power surge, or other event occurred and took out your operating system. If you want to check the Laptop Hard Drive outside of the computer to see if you still have Pictures, Music, Documents, etc.; you will have to open the back (Bottom) of the laptop case, remove the hard drive, and place it into a docking station or external hard drive USB connection. For a few dollars, TigerDirect on line has them. Once you have a USB attachment device, go to another computer, plug it in and seek that device. If it comes up missing your data, then you know the drive was cleaned out and it needs to be reformatted for use in your Laptop. Go back to the laptop and put the Hard Drive into the computer (make certain it is OFF) and place your Operating System (Win 7 or 8.1) in to the CD Drive and follow the progression from there. I suggest getting Win 8.1 as it is far better than all the other editions.
Dell Inspiron... | Answered on Jan 03, 2014
sata smart disk failure (Dell codes)
replace the hard drive
Dell Inspiron... | Answered on Aug 20, 2013
The BAD_SYSTEM_CONFIG_INFO ERROR occurs when your system is corrupt
so restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.and select "last known good configuration" in the boot options.
If this didn't resolve your error then simple get the Reginout to fix all the registry issues and errors which causing this annoying message
Dell Inspiron... | Answered on Jun 28, 2013
challagullan,
Unfortunately, Error 0146 indicates a failed/failing hard drive or bad drive sector. This means your hard drive will need to be replaced.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Dell Inspiron... | Answered on Mar 04, 2013
Check in device manager to see if it is installed. You might need to uninstall it and than reinstall.
Dell Inspiron... | Answered on Dec 11, 2012
I do not understand what you mean by get out. Please be more specific.
Dell Inspiron... | Answered on Dec 05, 2012
Dell Inspiron N5030 Notebook PC Logo
56 questions posted
Clive
Clive
Alun Cox
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
forgot password dell laptop windows 7
  • Computers & Internet
