Aiwa NSX-A777 Shelf System Logo
A
Anonymous Posted on Mar 16, 2013
Aiwa cx-na 303
Volume control
BRGARY3
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 10 Answers
  • Posted on Feb 17, 2015
BRGARY3
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
10
Questions
0
Helped
5380
Points
21
WHAT YOU COULD DO IN THE MEAN TIME IS, GO TO WWW,REMOTES.COM, PUNCH IN CXNA303 IN SEARCH BY MODEL, THEN GET THE MODEL NUMBER OF THE REMPTE, THEN GO TO EBAY AT WWW.EBAY.COM. TO GET THE REMOTE FOR CHEAPER, THEN IF YOU WANT TO REPAIR THE VOLUME CONTROL, FIRST, YOU WILL NEED A SERVICE MANUAL, CONTACT [email protected],in TELL HIM BRGARY3 SENT YOU, AND REQUEST A SERVICE FOR YOUR AIWA CXNA303, YOU WILL NEED A PAY PAL ACCOUNT FOR THE $9.00 PAYMENT, GO TO WWW,PAYPAL.COM, ONCE YOU HAVE THE SERVICE MANUAL, CONTACT AN ELECTRONICS TECH, HAVE HIM GIVE YOU THE PART NUMBER FOR THE CONTROL, THEN CONTACT ANDREWS ELECTRONICS AT WWW.ANDREWSELECTRONICS.COM CALL CUSTOMER SERVICE,ORDER THE PART, ONCE YOU HAVE THE PART, HAVE THE TECH PUT THE PART IN FOR YOU, THIS SHOULD SAVE YOU ABOUT $200.00.
  • BRGARY3
    BRGARY3 Feb 17, 2015
    WWW.REM.REMOTES.COM
4 Related Answers
Anonymous
  • Posted on Dec 12, 2009
SOURCE: Which Aiwa remote control unit to buy.
Went to manufacturer's website.
gopakumarg43
  • 76851 Answers
  • Posted on Jan 19, 2012
SOURCE: 3-cd drawer opened (aiwa cx
Hello
You have to open the unit to take the CD out of it. If you can, do this. If you are not able to doe this work, contact the nearest authorsed service center for Aiwa at your town. Aiwa is not a brand in market now, as Sony Corporation has purchased Aiwa. so it will be best to contact the Sony Authorised Service center at your town. OK.
  • 102366 Answers
  • Posted on Jul 02, 2012
SOURCE: What's your problem? i need a manual for an aiwa cx-na707
You may download a copy of the manual here.
Testimonial: "could not ask for better answers thanks so much"
calona_bc
Kathy McCharles
  • 3 Answers
  • Posted on Jul 14, 2012
SOURCE: where can i get a free user guide for aiwa cx-nmt520
gm rick hoffer go to this site then type in your model number good luck....http://esupport.sony.com/
Need manual for a Aiwa cx_na777
Certainly! Here is a basic manual for the Aiwa CX-NA777:
  1. Powering On and Off To turn the CX-NA777 on, press the Power button located on the top right of the system. To turn it off, press the same button again.
  2. Changing the Volume Use the Volume control knob located on the front of the system to adjust the volume. Turn it clockwise to increase the volume and counterclockwise to decrease it.
  3. Selecting a Source To select a source, such as the CD player or the radio, use the Function button located on the front of the system. Press it repeatedly until you reach the desired source.
  4. Using the CD Player To use the CD player, press the CD button located on the front of the system. Insert a CD into the tray and press the Play button to start playing the CD.
  5. Using the Radio To use the radio, select the Radio source using the Function button. Then use the Tuning knob to tune into the desired station. You can also use the Preset buttons to quickly access your favorite stations.
  6. Using the Tape Deck To use the tape deck, select the Tape source using the Function button. Then insert a cassette tape into the deck and press the Play button to start playing it.
  7. Adjusting the Sound To adjust the sound, use the Bass, Treble, and Balance controls located on the front of the system. These controls allow you to adjust the bass and treble levels, as well as the balance between the left and right speakers.
  8. Using the Clock and Timer The CX-NA777 features a built-in clock and timer. To set the clock, press the Clock button and then use the Tuning knob to set the correct time. To set the timer, press the Timer button and then use the Tuning knob to set the desired start and end times.
  9. Using the Remote Control The CX-NA777 comes with a remote control that allows you to control the system from a distance. The remote control features buttons for all of the main functions, including Power, Volume, Function, and CD playback.
  10. Troubleshooting If you experience any issues with the CX-NA777, such as a CD that won't play or a radio that won't tune properly, consult the user manual for troubleshooting tips. You can also contact Aiwa customer support for further assistance.
Note: This is a basic manual and may not cover all features of the Aiwa CX-NA777. For more detailed instructions, please consult the user manual that came with your system.
1helpful
I have an Aiwa cx-nma545 w/o the remote. What is the model number to the remote itself? Or do you know how I can replace it?
http://m.ebay.com/itm/AIWA-RC-ZAS05-AUDIO-SYSTEM-REMOTE-CONTROL-CXNHMA86-CXNHMA86U-CXNHMT75-/331729077190
Remote is no longer available from Aiwa nor most remote resellers. Ebay is your only source. The above link is to one available currently on ebay usa
1helpful
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' ManualsOnline.com
    audio.manualsonline.com > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Aiwa repair
I have 2 AIWA CX-NA303 in need of repair. Volume control works only with remote. Cassettes no longer play and doors get stuck shut. Each now has one door each that won't close. Where can I get these repaired?
I have an Aiwa cx-nma545 that I just hooked up to a Westinghouse SK-32h640g. The sound is very muffled. The sound is fine if I have it on cd or the radio but when on Aux Video I can barely here it.
On most TV's with speaker control there's a way to disable the TV's volume control effect on the level fed out to an external amplifier. Find it and disable it it or select FIXED for its level, or, while listening through the Aiwa, raise the TV's volume through its own remote and see if that affects what the Aiwa gets for volume.
Or, enable the TV's speakers but find the same interna lAudio setting and make it Fixed, but turn the TV volume down if you don't want to hear its speakers. That way, you could actually listen to the TV on its own speakers if you want, say, for casual watching of the Weather Channel or news, for example.
3helpful
2answers
I need a part # for the volume controle on an Aiwa
The "volume control" on your Aiwa is in fact what is called an "encoder". These can fail. They work in concert with the microprocessor to control the electronic volume control IC. Yes this part can be replaced. Try calling Sony with your model number and request the part number for the volume encoder. They should be able to help.
Dan
1helpful
I need a manual for an AIWA CD/Radion Model CX-NA 777.
what is the problem with your aiwa, i have worked on several of them in the past.
2answers
Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
My Remote Control Unit for my Aiwa Digital Audio System CX-NA707
It would be a lot quicker (and could be cheaper) to spring for a universal remote.
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mohammad Abumuailek
Mohammad Abumuailek
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
