20 Most Recent
Aiwa NSX-AJ20 CD Shelf System Questions & Answers
Cannot turn off the Timer
Can you set the start/stop time to read 00:00? If so try that, it shouldn't go off at all. Another possible solution could be to turn it off and unplug it directly from the wall.... leave it for a minute or so, plug it back in and leave the timmer alone all together. If it has an internal memory, leaving it unplugged for a few minutes might reset the system. There might also be a main reset button hidden somewhere but you will have to look that up in the manual.
I have an Aiwa nsx-aj20. The CD player skips
If that is the case that the cleaning disc skip, i will advice you clean your laser lens manually, follow this steps to clean your laser lens manually.
Remove
the outer casing of the CD player. Remove the screws that mount the
top casing onto the bottom of the CD player and slide the top casing
off. This will expose the CD deck, which houses the laser pickup lens
Find
the lens. The lens will be glass and under the CD clamp. The lens will
probably have a blue tint to it. If you are having trouble finding the
lens, you could shine a light on the components and watch for the
reflection
Use
a cotton swab and some spirit to gently wipe the lens. Just a
quick scrub will do. Dry the laser pickup lens with the other end of
the swab
Give
the lens a few seconds to dry and replace the covering of the CD
player. Test the efficiency of the player. If necessary, repeat the
process, if the problem still persist, replace the lens.
Take care.
When plugging in system will
aiwa stereos were notorious for having poor solder connections ,especially on their regulators , if you have solder experience i would do a visual look for poor solder
My AIWA turntable (1989 but still in excellent
Please try and lift the turn table off the casing itself (wheel only) and check if it is belt driven, or by gears. If it is belt driven, the belt might be worn or streched, and needs to be replaced
How do I get my cd to eject? What can I do? I don'...
On these systems with the CD player being on the top, you can get the disk out by either removing the top cover via 6 screws , ( 2 on either side and 2 on the back ) or the screws on the side and back of the hifi that hold the case on, they will need to be removed. Then pull the cover up and slide out. Then if it should be easy to pull the disk out.
Radio turns on at midnight automatically, I do not
To shut off the timer function (turns the unit on at a certain time):
Press the timer button (on the system itself) until the little clock icon disappears from the units display. This deactivates the timer.
Alternatively, you can reset the system to factory default (clear all user inputs and setting from memory)by:
Start with the power on
Turn the unit of using the power button.
Turn the unit on
while pressing the
Stop/Clear button.
Here is a link to a PDF version of the manual free to download:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Cheers,
Jer
NEED MANUAL
Hi
Just follow this link
http://www.retrevo.com/support/Aiwa-NSX-AJ20-manual/id/1076ci366/t/2/
and click GET MANUAL
scroll down and type your email address and number showing in that box below...click DOWNLOAD
thats all..
-- Rajkumar
