20 Most Recent Aiwa PX-E860 Turntable Questions & Answers
How to adjust AIWA Turntable PX-E860U speed
Found this post trying to troubleshoot my Aiwa PX-E860U-after replacing the belt and lubricating bearings, the speed was off. 33 setting was playing slow. Here's the fix: 1. unplug and flip upside down 2. Locate the two holes marked 33 & 45 where black dots are visible underneath 3. Using a very small flat screwdriver(I used one from an eyeglass repair kit), adjust the speed clockwise for faster, counterclockwise for slower this is a DIY solution, so not perfect, but it works. I played the tracks along to a Spotify recording to get a good match. Hope this helps someone else!
9/11/2021 5:31:42 PM • Aiwa PX-E860... • Answered on Sep 11, 2021
The drive belt on my Aiwa px-e860 turntable has
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
1/22/2020 6:09:58 PM • Aiwa PX-E860... • Answered on Jan 22, 2020
A needle for AIWA PX-E860?
try this company?
mailto:[email protected]
5/26/2019 11:32:10 AM • Aiwa PX-E860... • Answered on May 26, 2019
My Aiwa px e860 record player arm is too heavy how do I adjust it?
If you put the maker and model number into Google you will find a service manual free for the make. That should help you sort out the problem. It's just a question of getting the weight at the other end of the arm adjusted right.
12/18/2016 11:47:32 PM • Aiwa PX-E860... • Answered on Dec 18, 2016
The start and cut buttons do not work
Does the platter rotate if you manually move the arm towards the platter? if not, the belt is requiring a replacement
2/23/2016 1:38:47 AM • Aiwa PX-E860... • Answered on Feb 23, 2016
2answers
I have the Aiwa model
Hi, no. Cheers John. [email protected]
1/27/2016 10:59:19 PM • Aiwa PX-E860... • Answered on Jan 27, 2016
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
1/16/2016 6:37:36 PM • Aiwa PX-E860... • Answered on Jan 16, 2016
How do I eliminate turntable squeaks?
Clean dust out. Get some Silicone Grease and use that on moving parts. Use a straw in your ear to locate the source of the noise. Silicone Grease can be found at Maplin (in the UK) or Radio Shack (or a shop like it) in the USA.
12/18/2015 1:27:04 AM • Aiwa PX-E860... • Answered on Dec 18, 2015
Sound from a Aiwa PX-E860 turntable
Only a guess here but are there any electronic components or circuit boards that the WD40 may have covered? If so it may be wise to remove the WD40 from these items as it may have electrically changed some component values and altered the circuit function. Worth a try.
11/26/2015 2:43:34 PM • Aiwa PX-E860... • Answered on Nov 26, 2015
2answers
No sound from speakers when turntable playing records
hi,, please check your RCA cable...or replace it possible...
8/4/2015 12:08:04 AM • Aiwa PX-E860... • Answered on Aug 04, 2015
Reconnect the belt on an AIWA PX-E860 turntable
To replace a turntable drive belt. Before starting any work on your turntable disconnect it from the mains power supply. Remove the stylus or complete headshell to prevent any accidental stylus damage. 1. Remove the rubber platter mat to expose the platter. 2. Put your thumb and forefinger through the two round holes either side of the centre spindle and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage. 3. Remove the old belt and wipe the platter and motor pulleys with an alcohol swab to remove any old belt residue. 4. Place the new belt around the platter pulley making sure it is sitting flat without any twists. 5. Flip platter over to the right way up. A correct fitting belt will stay put and an over sized belt will fall off. 6. You will see 1 or 2 large rectangle or square shaped cut outs in the platter near to the outer edge. Through one pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley. 7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt. 8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly. 9. Replace the rubber mat and then run the turntable to ensure correct operation. You have now successfully completed the process. MUSIC IS LIFE, LIVE IT LOUD. Copyright.. Styluscity, John Harrison.
12/18/2014 12:49:49 AM • Aiwa PX-E860... • Answered on Dec 18, 2014
2answers
The turn table is going round but its playing the record to fast the speed seems wrong
Hello!are you sure, that your speed selector is on 33.3rpm, not 45?assume, it's in correct speed settings. do you know, that across the ocean power grid AC frequency is 50hz, in US it's 60hz. Means: ac motor will spin faster, than it should. If you bought this unit abroad, that's where is your problem at. some expensive units have 50/60hz pulleys switch, some not. Especially, if it's DC or direct drive motor. Check your owner's manual for specifications. May be you find an answer. If not, there is a problem with motor's regulator, which is built in(DC motor). Turntable is a belt driven. If you won't find 50/60hz adjustments, take it to repair shop.Good luck,Alex.
11/27/2014 3:52:03 AM • Aiwa PX-E860... • Answered on Nov 27, 2014
Can the aiwa px e860 be run independently from a hi fi unit
You would have to make an independent power supply for it. It would help if you can find the system service manual. This should show what the power supply line is. You could then build a power supply. Generally these system turntables don't use one greater the 12 volts DC, and there are power adapters pre-built that would do the job. But you would need to adjust the voltage to get the speed right.
10/18/2014 1:03:11 AM • Aiwa PX-E860... • Answered on Oct 18, 2014
Turntable spins constantly and needle wont go down on record
Does the deck have a Lift/Lower lever for the tone arm? Make sure that it is set to the Lower position
9/12/2014 2:47:06 AM • Aiwa PX-E860... • Answered on Sep 12, 2014
Aiwa turntable not playing through the speakers
Has the amp got a dedicated phono socket for the turntable? If you are using a tape or aux socket it might not have the pre-amp needed to hear the deck. If your amp doesn't have a socket for the deck, you will need a magnetic cartridge pre-amp. Also check the connections to the cartridge, they might have come loose.
7/25/2014 12:41:40 AM • Aiwa PX-E860... • Answered on Jul 25, 2014
How to replace stylus on AIWA stereo turtable
the old stylus snaps off. pull evenly straight out. The new one snaps on in its place. Do not touch the needle as it is easily damaged.
7/14/2014 2:06:21 PM • Aiwa PX-E860... • Answered on Jul 14, 2014
THE DECK WONT START
Try removing platter and checking belt is correctly fitted. Keep em spinnin, John. Stylus City
6/21/2014 8:43:45 AM • Aiwa PX-E860... • Answered on Jun 21, 2014
Wont start as there is no power to the deck
A faulty on off switch can sometimes cause the power to fail. Some decks have micro switches that get bent out of place.
5/8/2014 4:40:36 PM • Aiwa PX-E860... • Answered on May 08, 2014
Wont spin
Hello Bella, This is a belt driven turntable. Most likely, your drive belt has fallen off. It may be too stretched to stay on. To check this, remove the rubber platter mat. There should be holes in the metal platter, which if you rotate it, you will see the belt and the motor pulley. Remove the metal platter by grasping the holes. It should lift off. When the platter is off, try to slip the belt over the inside flat part of the platter. It should be snug. If it just falls off, the belt needs to be replace. For more information or parts, please go to my website, AUDIOSERVICECLINIC.COM. You can contact me through the website, and we can take this issue further if need be. Thank you, Dave Audio Service Clinic
4/14/2014 5:30:02 AM • Aiwa PX-E860... • Answered on Apr 14, 2014
0answers
Belt
Be the first to answer 4/13/2014 3:31:03 AM • Aiwa PX-E860... • Posted on Apr 13, 2014Be the first to answer
Aiwa PX-E860 Turntable Logo
168 questions posted
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mohammad Abumuailek
Mohammad Abumuailek
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Aiwa Audio Players & Recorders
Most Popular Question
sound from aiwa px e860 turntable
  • Audio Players & Recorders
