SOURCE: need driver for sony vaio VGN-CR220E built in web cam, motion eye
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E
There u go, all availble files for Vaio VGN-CR220E and Vista
Good luck
SOURCE: i need drivers for sony vaio vgn cr220e for
You can get the drivers from the sony offical site.
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER&TC=b2b
Thanks
Smith
SOURCE: Laptop will not boot, Sony Vaio VGN CR220E, lights
I need you to try a few things.First remove the battery,memory no power whatsoever.Press and hold the power button for twenty seconds.Replace the memory then the ac cord and try again.Remove the power only this time and press and hold the power button again.Now replace the battery and the power adapter.Power up and you should work if not you will need to replace the motherboard.
Good Luck
SOURCE: I have sony vaio vgn a215z and volume buttons don't work
if the function key of your keyboard not working, the primary reason is the chipset driver of your mainboard not installed. you need to load your cd/dvd driver to your cd/dvd rom then you can find the list of drivers and select the chipset driver click it and follow screen instruction after installation restart and done. be sure to locate the chipset driver base of your OS.
SOURCE: hi, i use latop sonyvaio vgn-cr220e
Install the Memory card Driver for windows vista to resolve the issue as the Driver for the Windows vista will work with windows 7 OS.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR220E&upd_id=3044&os_id=28
