"Low Voltage Power Supply" in a laser printer usually means the AC to DC power supply in from your wall outlet. The "High Voltage Power Supply" is often in the center of the printer and provides the high power required for imaging internally.
Is the FAN (bottom right of the front) of the low voltage power supply block working? Is the FAN connector connected correctly?
Check to make sure connection of the FAN connector. Replace the low voltage power supply unit. Replace the FAN motor. Replace the low voltage power supply unit.
In that case the problem of your television is the power supply.The power supply have low voltage output so that the board of your TV cannot drive,so that the TV wont turn on.The power supply have leak capacitor that may cause of abnormal voltage.The output voltage of the power supply is +5V, +12V, and +24V.So the power supply is the problem its need to repair.Thanks
To remove the low voltage power supply, Take off the side covers. the power supply is on the rear right hand side of the printer. Just remove the screw's and the cable's connected to it and your done. Don't confuse it with the Hi voltage power supply which is on the Left side of the printer as your facing it head on from the control panel.
