Picture freezes after only a few minutes of being live
Used to work fine, but now my pictures freezes after just a couple of minutes..The last image before it froze stays on the screen, they can still hear me and I can see them real time. I hang up and call again and it works for just a few minutes again...
Re: picture freezes after only a few minutes of being...
Normal 0
Web Camera’s have to besetup on the program they are to be used with.Just installing the camera on your computer does not set it up tobroadcast on messengers or Skype. Each program has Options that have to be setup in order forthe Audio and Video to function properly.
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Hi there: Some symptoms of a defective CCD
include distorted images or abnormal colors, scratchy purple lines,
blank or black pictures, and/or black videos with good sound being
recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When
a picture is taken, the CCD is struck by light coming through the
camera's lens. Each of the thousands or millions of tiny pixels that
make up the CCD convert this light into electrons. The number of
electrons, usually described as the pixel's accumulated charge, is
measured, then converted to a digital value. This last step occurs
outside the CCD, in a camera component called an analog-to-digital
converter. In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it. Hope
this helps; also keep in mind that your feedback is important and I`ll
appreciate your time and consideration if you leave some testimonial
comment about this answer.
Hi there: A CCD problem would explain the
black or lines on your pictures and the lines on the LCD (since the CCD is used
in digital cameras. Some
recorded on the camera's flash card. When a picture is taken, the CCD is struck by light
coming through the camera's lens. Each of the thousands or millions of
tiny pixels that make up the CCD convert this light into electrons. The
number of electrons, usually described as the pixel's accumulated
charge, is measured, then converted to a digital value. This last step
occurs outside the CCD, in a camera component called an
analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your
feedback is important and I`ll appreciate your time and consideration if
you leave some testimonial comment about this answer.
It sounds bad ccd imager chip in your Canon camera and ccd imager chip will be replaced to get live view in camera mode to take pictures. Canon offers free of cost repair for few models with same problem, click Canon CCD Imager Advisory for details and ask Canon for free repair of your camera. Thanks.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype. Each program has Options that have to be setup in order for the Audio and Video to function properly. A. Skype Setup: After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows: Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card. Then click on the Video Settings. The camera, if Installed Properly, it will come up and show a video picture. Then, on the bottom of the page click save. The camera and audio should function properly. Your friends and Family will now be able to see and hear you. B. Yahoo Setup: After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML ) set it up as follows: Go to Messenger at the top left and click on it. Next go down to Preferences and click on it. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card. Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window. C. Windows Live Messenger: http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X. Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar". Next go to the Menu Bar on right side, click on " "Action." Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions. NOTE: Your audio and video should work. Enjoy. When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to. D. AIM (AOL) Messenger: http://dashboard.aim.com/aim On the VIM sign-in window, click on Edit. Then click on Settings Enhanced IM. Next click on Enhanced IM. Then click on Audio Video. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer. The Audi Video drop downs are Microphone Speaker Camera The audio and camera should function now. Additional information to use with VIM settings. Adjust Your Audio and Video Settings: In order to adjust your audio and video settings, please follow the steps given below: 1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button. 2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working Properly. Follow the on-screen prompts. Notes: The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts. images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the Picture-in-picture (PIP) display. After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
The more you play set the longer it will last, it sounds like you may have poor connections, cold solder joints try soldering around flyback transformer.
