20 Most Recent Canon PowerShot SX110 IS Digital Camera Questions & Answers
To fix your issue with the Canon Powershot SX110 IS Digital Camera, try cleaning the lens. A huge issue with malfunctioning pictures can be as objective as a dirty lens. If that doesn't solve the issue, try to make sure that your flash is working to its full power. If you are taking a picture in a low-light area and the flash isn't giving off a strong enough light, this will cause grainy/noisy dark photos. Lastly, try playing around the with settings on the configuration screen. Sometimes digital cameras can malfunction, even after reformatting, and will apply alternate settings from what you originally had set.
Hope this helps!
-Anonymity
Canon PowerShot... | Answered on Jul 11, 2019
Try performing a complete reset - this should iron out any electronic glitches.
Canon PowerShot... | Answered on Jul 27, 2017
https://support.usa.canon.com/kb/index?page=content&id=ART103443 here you go
Canon PowerShot... | Answered on Dec 27, 2015
This is probably a battery issue and not a camera issue. Batteries with low output or low power can be due to them sitting and not being used for long periods of time. This can affect their ability to get a full charge as their "memory" is reduced regardless of what the charge light indicator displays. Even taking a battery that has been sitting for a long period and charging it to full charge, might only have limited power. Some of these can be returned to almost full capacity, but it takes multiple, repeated, alternating, charges and power deletions to rebuild the memory. In many cases, however, the battery just needs to be replaced.
Canon PowerShot... | Answered on Dec 14, 2015
Have you downloaded pictures to your computer to see if the pictures are ok, and it's just the display? If not, worth testing. If pix are ok, then it's just the display that's bad. If the pix are bad, get new camera.
Canon PowerShot... | Answered on May 28, 2015
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Canon PowerShot... | Answered on Nov 07, 2014
Make sure you are using Lithium batteries. Alkaline batteries will go dead immediately in this camera. I've tried it.
Canon PowerShot... | Answered on Sep 30, 2014
The Canon SX110 doesn't have WiFi capabilities. Or are you asking about a different Canon camera?
Canon PowerShot... | Answered on Jan 02, 2014
Replace the date/time battery on the side of the camera.
Canon PowerShot... | Answered on Dec 27, 2013
Ana, That is not much to go on, but I will try.
Not working, is that you don't see any response on the camera? does the screen go on, and not telling any error message.
Or does the camera go on and you just can't make any picture?
Most problems occur when the batteries are old or the battery contacts are dirty (oxidised) be sure the contacts of the batteries and in the camera battery compartment are clean. Be sure your batteries are not worn out. Test with a set of new ones.
Look if accidentally your memory card is locked. the switch should be pointing to the top (where the golden connection point are).
If you still have a problem, please let me know.
Canon PowerShot... | Answered on Nov 14, 2013
Given the age of the camera, it would be cheaper to replace it than to repair it.
Canon PowerShot... | Answered on Nov 09, 2013
It's the button marked with a one-handed clock. In shooting mode, press cursor-down, then use cursor-up/down to select an option.
Canon PowerShot SX110 IS Digital Camera Logo
180 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
canon sx110 scroll jog
  • Cameras
