Hello, I recommend that you contact your carrier and make sure your a provisioned properly and they send you service books . this usually fixes the issue
Hello ? check also "Firewall"options in options/security/firewall . May be blocked by ascidentally .Hello ? check also "Firewall"options in options/security/firewall . May be blocked by ascidentally .
You can't post conmments that contain an email address.
You need to contact your service provider and have your Voicemail reset. The carrier can reset everything. This includes fixing your incoming text problem.
it is rare that a large text will block your incoming textes, clear all your textes from your inbox, outbox etc, if you can call your network provider, and as them to send you an update text so that you can send and receive textesan update text will clear any memory from your textes. Some networks will be able to update it for you over the phone .. hope this helps mate
go to message setting, text message, text meassage center, then try changing to another center, ( i've got 3 dif centers to pic from but only the first one lets me send text messages)
you may have to check your settings on the nokia- may not have text message 'up-loading'- 'sending' set up. your service may allow 'free' incoming- but not sending! check your phone settings- may need to go on-line to alter your settings! or find info to set your phone! good luck!
hi there, call the customer service of your service provider ( AT&T,Vodafone,Verizon etc)....they will set up message center number on your phone , the one that you have might be incorrect...your mobile operator will send you sim updates that will refresh the settings ....and then you will get the text message options cheers
Somce cell phone carriers can block outgoing texts, separately from incoming texts.. You might want to check with your cell company and see if they accidentally blocked your incoming.
