There should be a skinny nut on there so that has to come off and the jack is soldered in so heat up the solders and pull the wires off but mark them so you no for sure were they go when you install the new one . for install just go backwards from the steps to take it out. you will do fine but if you cant solder i would suggest repairman cause to much heat and things go wrong.
Repair or replace input jack.
