Samsung HLR5067WX 50" Rear Projection HDTV Logo
A
Anonymous Posted on Feb 22, 2013
I need a pcboard P59A CHAMP-PCB SUB BP41-00070C
1helpful
2answers
How do I replace a subwoofer potentiometer ?
If the 10k resistor is the variable volume one then change it.Some sub amp plates have epoxy all over the pcboard.Hard to remove type.I think yours is soldered to a sub pcb and need soldering experience to remove.
tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
How to reset e001
An error E001 should have a detail code with it.
Detail Code 0001:
Cause
The fixing temperature has increased abnormally
  • The main thermistor (TH1) has a short circuit.
  • The fixing heater drive circuit has a fault.
  • The DC controller PCB has a fault
  • The image processor PCB has a fault.
Description
The output of the main thermistor has exceeded 220 C.
Detail Code 0002:
Cause
The sub thermistor has detected overheating.
Description
The output of the sub thermistor has exceeded 235 C.
Detail Code 0003:
Cause
The sub thermistor has an open circuit
  • The sub thermistor has an open circuit.
  • The SSR has a fault.
  • The DC controller PCB has a fault.
Description
I would suggest calling the copier repair personal.
Need a wiring diagram for this pcb
We have absolutely no idea what PCBoard you mean. You don't mention a make/model.
The PCB in my LG 32" LCD is burnt due to power fluctuation....the technician says it costs around 13 thousands....where do i get the original PCB for low price ?
Why not employ an engineer from an LG Service Department to repair it? Most power supplies run hot and if the PCBoard is not serviceable, surely you should contact the manufacturer and lodge a complaint as items of high value should last a reasonable length of time.
I can't get the self focus working
Replace the sub deflection board thats what has the convergence circuits on it. Heres a link to the board for your model. http://servicemanuals.vstore.ca/product_info.php/pName/p59a-pwr-def-board/cName/samsung-parts
Convergence issues
Yes the HC-P4252W and the HC-P4752W are both P59A chassis so they both use the two STK392-010 Convergence amp iCs that are located on the sub deflection board
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
