Red light flashes nine times and sound comes on but no picture but picture does work sometimes
The blinking light codes can be found at this website.http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
SOURCE: projection tv wont turn on
a sony should only blink up to 8 times. If its continuous without any pause that usually means
No reply from the jungle (data bus is busy, shorted to ground or held
high), IK video path is defective.
Count your blinks again. let me know.
SOURCE: No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B
LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
SOURCE: Sony Grand Wega 55 inch
6 blinks is an indication of a missing voltage. It's not the lamp or balast. It may be an indication of a thermal or heat trouble. These sets have thermal protection because of the heat created by the lamp. The thermal fuse may have opened. If this has happened you should have professional check it out. This set has 3 or 4 fans. These should be checked out or replaced. I suggest a Sony authorized repair. This is not a repair I would recomend for you to attempt. This set keeps a record of it's falures and the pro can check for any other trouble also.
SOURCE: LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
