Right now the system appears to default to 8 rings before voicemail picks up. How do I change that?
SOURCE: Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
SOURCE: Chg number of rings to voicemail on M7310
Is your system a BCM or a CIC/MICs system?
I know you most likely will not know, so I will give you both ways to change this... they are pretty well Identical, but there is one extra set if your system is a BCM, that is if the set programming can be done.
ok... lets get started!
Go to a programming set:
-> FEATURE * * 2 6 6 3 4 4 (CONFIG)
-> User ID: 7 3 8 6 6 2 (SETNNA) [this is the extra step I was talking about]
-> Password: 2 6 6 3 4 4 (CONFIG) [this is the default password, but could have been changed by the programmer]
Now you will have to look at your LCD for 3 arrows
<- Heading....Enter->
<- Back .......Next->
You will not see these words in the LCD display, you just have to look for the 3 arrows that correspond.
-> You will now see TERMINALS&SETS, and press the ENTER button
-> type in the extension of the set (eg:2338), now you will see 2338: NAME
-> press ENTER and you will see LINE ACCESS press NEXT till you see CAPABILITIES
-> press ENTER and look for Call Forward No Answer
-> press CHANGE and type in the new name pressing the # button to advance to the next letter.
-> Hit the NEXT button to save
-> press the HEADING arrow to back up and press FIND to look for next extension that you want to change.
-> after all the changes are made, press the RLS button to end programming.
