Need instructions for Necchi sewing machine, model 524fb
Here is 2 links for a manual,, you can choose which one you want
http://www.sewingpartsonline.com/instruction-manual-necchi-522-and-524fb.aspx
http://sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/524FB_Instruction_Manual.htm
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
SOURCE: manual fornecchi-alco sewing machine model 301
I have an ALCO 2200. Luckily I have the manual. If some one need the manual, I can photocopy and send it to you, if you do not mind paying the postage. :)
SOURCE: necchi sewing machine
i repair a lot of sewing machines as a hobby .. the necchi is one of the better ones .. they are easy to use and work well .. i almost always dontate the repaired machines to places like "womens shelter" .. "home for troubled girls" or just give them to someone that has nothing or cant afford new machines ... it sometimes makes a difference in their life if someone helps them get started .. modern machines vary from really cheap junkers that somehow work to really expensive machines that do everything but are completely out of reach for many.. the old necchis are better than many new machines but no one knows that .. so typically they sell for only $20 to $50 ... but if you donate a working machine to someone it can help, then its worth it weight in gold ..
SOURCE: white model 524FB sewing machine
I could not find one - try contacting White's customer service - http://www.whitesewing.com/customer.asp
