Check the mic and connections all through its input into the unit. I would check the cartridge of the mic for continuity for the reason that (I think but not 100% sure) on this model, I think there has to be sound at the mic or it does go silent in vocode mode. This is how it digitizes the mic and keys together. The played keys cannot put onto pitch the sound it is NOT picking up at the mic. I think there is a problem with the mic.
My EWI 4000s started to play by its self making a loud low note and then it stop and now it won't play at all. I Reset to Factory Preset but that didn't help. What do I need to do to get it to play again?
1 Un screw all the screw on black panel, but must remember where each on goes, but Be careful not the two screws in side mouth pice which holding the pitch bend unit. 2. open the battery cover remove all the battery 3. Remove the 1/4 earphone nut, and all screws on the silver metal case. (Under the black plastic ), you don't need to remove any screws from the "key" side 4. Use something to pull the battery Cartridge sideway out from Main attachments, but not all the way out from the ewi case, because you can't, the plastic case structure will be in the way, 5. Use some flat pice metal like dinning knife insert in to between black and sliver metal to separate the two parts, start from the mouth pice end, once you open wide enough the battery cartridge can be remove from the case out. Now you can open the Ewi 4000s and see the two HX nuts that holds the strap mount, put some Nail polish on it before you tie them up.....Warning.. You must pull the battery cartage sideway out from its electric plugging mount before you are trying to separate the plastic and silver housing otherwise you will damage the circuit board. That was What I did to mine. Good luck and may God provide you wisdom for this.
hi, i have a YAMAHA WX5, and want to know if it's to use a Vocoder? Mike Phillips is the same, or if it only works with the EWI 4000s? and as a connection is made? thank you!
Here is one link:http://www.patchmanmusic.com/ Although they do not ship hardware outside the U.S. there is lots of good info. This is a good store and they ship Internationally:http://www.sweetwater.com/c966--Wind_Controllers Contact them to see if they have the cable in stock.
This is the site:http://www.elfa.com.au/products/product+details?pid=71959 Electric Factory I88 Plenty Road Preston, Victoria, Australia Tel: (613) 947-41000 www.elfa.com.au List price for the EWI usb was$999.00. If this helped please rate me.
Please try to reset the ewi. You can do this like this: Shut down ewi. Press down the four little white buttons Level, FX, Setup and Trans. Keep them pressed while starting up the ewi.
This is a factory reset.
I've got the solution.
Turn the EWI off.
Press the LEVEL, FX, SETUP and TRANS buttons all together.
Turn on the EWI.
This is a Reset to Factory Preset.
Greetings Fred Roubos.
