I have a mac but it's a new one. drivers are installed. just don't know how to do it Hi, I have a problem with printer. I want scan to computer. I lost my manuel book. I cant find it when I moved here from north. So can you help me how start from Scan to Cpu please thank you..
SOURCE: No Scan Options Error Message
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly.
Solution
Scan documents using Windows Fax and Scanning or Paint.
Scanning with Windows Fax and Scanning
Scanning with Paint
Cause
The drivers in the Windows Vista operating system do not support button press functionality on the printer.
link to above info from HP
SOURCE: scanning neg
Check the Epson site for Manual in PDF format[This may also be on the software disk]
SOURCE: HP Photosmart 3210xi Scanning Issue
no scan options refer to device documentation to troubleshoot
SOURCE: cannot scan to mac from a cannon mf4150
There is not yet Mac driver support for the scanner portion of this printer. The printer should work fine, but no scanner as of yet. Too bad no one told me at the Office store when I bought it.
Title: Scanning a document
Hi, at first connect your scanner with your pc then-
?? Install your driver
?? After installation restart your computer.
?? When your computer start, go to "Start " and see the new installed software, open it and choose "Ulead photo Express" any thing which is your scanner supported.
?? Then open your scanner and put document into the scanner.
?? Close the cover.
?? In scanner a scan button is there , just push it.
?? Scanning will be start automatically.
Thanks!
