The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Thanks but I need the date stamp as part of the image .jpg file - the EXIF file is not uploaded to my PC and I need to be able to forward the photo to others complete with the date stamp. This is easy with my Minolta camera as I just set the camera to stamp each photo and the job is done. Is there any way I can get the Lumix camera to do similar?
The EXIF data is part of the image JPG file. If you forward the file to someone else the data will be included. The DMC-FX3 will not mar your images by scrawling a string of numbers across them. The closest it will come is to record the vacation day on the photo. See the "Recording which Day of the Vacation You Take the Picture" section of the manual.
Many thanks, I have now found the date and time attribute in MS Picture Manager - so I just need to find some software to print it.
SOURCE: Date not appear on screen
Your internal back-up battery is empty, please replace the internal battery and date will apear.
Rob
SOURCE: I have a lumix DMC-FS12/dmc-fs62. date and time
it will show up on the exif and in windows too. personally i am glad it does not blend it in on the photo. and if you have to prove you can always shoot a newspaper headline and one news item of that day
SOURCE: how do you date stamp panasonic lumix photo
The date and time (and a lot more) are stored with every photo in its EXIF metadata. This data stays with the photo unless explicitly removed. Just about any photo viewing/editing program should be able to show you this data. If you want to print the date, please refer to the documentation for whatever program you're using. Depending on the program and printer, you may print the date on the image, in the margins, or on the back.
