Time is incorrect on Nortel IP1140E telephone Model NTYS05
SOURCE: time on phone
Programming should be done from the M7310, M7324 or the T7316E set.
Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
If asked for a password enter the same 2 3 6 4 6.
If that doesn't work you may have the newer Compact ICS or the Modulur 0x32 control unit wish will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
When in programming just press the (next) button until you see what you want to change. Then press (show),then (change) if you want to change it. If you pass it, just press (back)
Example: To change the Time & Date Press (next) until you see Time & Date. Then (show) Then (change) Then (change) again, change it if you need to, Then (next) again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press (next) until you come to the (Hour). Then Change it. Then press release (RLs) when your done.
To get out of programming, just press the release button (RLs).
SOURCE: time change
Below is a link to instructions on how to change the time on a Norstar system
Norstar Time change
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password
Retry
Step 2
Press 266344
on the dial pad buttons to enter the DEFAULT password. Your password
MAY BE DIFFERENT! The display will show the following options:
Hour: 01
Next
Change
Step 3
Select CHANGE - the display will show the following options:
Hour: __
Cancl
Step 4
Use the dial pad buttons to enter the hour. You must use two digits for
all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM
or PM. Select CHANGE and OK to choose PM.
AM
OK
Change
Step 5
After you have entered the hours, select NEXT. The display will show
minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the
RELEASE (RLS) button to end your session. The time will be changed and
the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00
Next
Change
Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99
Next
Change
Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
SOURCE: T7316e Nortel Meridian Norstar Telephone MANUAL
Not too sure what type of manual you are looking for, but here is a useful link to have for a Norstar system information.
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
SOURCE: looking for a manual for a Nortel Telephone -
http://www.wedophones.com/NorstarManualsLead.htm
Hope this helps you.
1. Press Feature x x 8463 (x x TIME) you should have Password displayed on your telephone.
2. Enter 22742 (BASIC) or 23646 (ADMIN) you now should have Hour on your display.
3. Now press Change and enter the correct hours using the key pad
4. Press NEXT and you should have Minutes displayed on your telephone, now press CHANGE and enter the correct Minutes.
5. Press NEXT and you should have Year displayed on your telephone, now press CHANGE and enter the correct Year.
6. Press NEXT and you should have Month displayed on your telephone, now press CHANGE and enter the correct Month.
7. Press NEXT and you should have Day displayed on your telephone, now press CHANGE and enter the correct Day.
8. Now you will have ---End of List--- displayed on your screen, you can now press Rls or handset down button to come out of programming.
