After I reinstuled windows vista the internal (builtin) speakers do not work. The headset works properly when I plug it.
Unplug Headphones. Open Control Panel, Sounds, select Speakers. Perhaps Headphones are set as default. The Dell Audio drivers can be found here: http://www.dell.com/support/drivers/us/en/04/Product/vostro-1400 Do ALL your Windows and Dell updates, if you haven't already, after a install.
SOURCE: sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
SOURCE: internal audio was not working properly.
It sounds like a driver issue. you can download the latest driver from dell. here is the link
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R90698&SystemID=LAT_PNT_CEL_D500&servicetag=&os=WW1&osl=en&deviceid=2551&devlib=0&typecnt=0&vercnt=6&catid=-1&impid=-1&formatcnt=1&libid=3&fileid=118248
SOURCE: i have dell inspiron 1318 with windows vista but
You'll need to download the driver for your microphone.
After you've tried that then there's something wrong with it.
SOURCE: i have dell Inspiron 1420,
It must be a Volume device drive problem,please try to update your volume device drive software,find your original dell Inspiron 1420 volume device driver software or download it from www.dell.com
SOURCE: i have an inperion 1525 and after i reinstalled
It sounds like a driver issue. Go to http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs and enter your service tag. It should give you a list of available drivers for your system. Make sure that it specifies Windows Vista in the drop down menu. Check for audio drivers and install the most recent one.
