20 Most Recent
Dell Vostro 1015 Laptop Computer (Intel Core 2 Duo T6570 320GB/4GB) (bqetbf23) PC Notebook Questions & Answers
Error code 0151
hard drive failure. replace with new drive and reinstall whatever os you choose. i recommend 240-480 gb ssd.
Delay start
Apparently your system seems to have a large boot load, Therefore you can perform a start-up check by MS config. Please follow the steps below:Open start menu then click Run.In Run windows type Msconfig and then press enter.You will see a window opened with different Tabs in front of you .Go to the Tab Start-up.Then click disable all or UN-check all option.After that your system will prompt you to apply changes and restart your PC.Go ahead and accept that option and you will see a drastic change in your Start-up. Thanks
Turned of fan
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Code 10 is not starting
This error is basically saying that Windows, for one reason or another, cannot communicate properly with one of your programs. This communication problem is usually caused by out-of-date, missing or corrupt device drivers. ... Select Start > All Programs > Windows Update.
This copy of windows is not genuine
i used to get that also, I wrote down windows numbers from windows sticker on the side of machine, (needed magnifying glass) and went online to windows verify, after they scan it, it came out good
HOWCAN FIND MACADRESS WIFI LAPTOP VOSTRO1500?
Open a command prompt ( Windows key + R to open Run box, then cmd), and type
ipconfig /all
and look for the wifi adapter. The entry labelled "Physical Address" is the MAC address. It will look something like 84-3A-4B-C8-E9-B7
(Your router might want it entered in the format 84:3A:4B:C8:E9:B7)
Cpu overheating
The cooling fins on the processor chip are plugged with dust. The fan may not be turning fast enough. If that's the case you'll need to replace the cooling fan
Wifi hotspot
WiFi will in the laptop will connect to a wireless router or a hot spot. The laptop itself has no hot spot built in.
