Me! Jonathan Haberer. Im the middle son of the late G.F.Haberer. Check out Haberer table on Face Book. I should have the first run of motors in by late November! You can call me any time at 678-230-8480
I told you before and now also i repeat these all massage and SMS are fake so don;t believe that one, & don't waste you time to achieves that offer letter.
I have provided instructions on how to save setting on the receiver and remote plus instructions for learning mode. I hope this helps.
Ray Calo
DISH Network
Back Up Remote/Receiver Data
Receiver: 222k and 722k
Verify that the customer has an unobstructed LOS and is within 10 feet of the receiver. The customer will need to direct the remote toward the receiver for the duration of the System Wizard setup.
Press and hold the number 0 until the pop-up 380 appears on the screen.
Verify that the System Wizard says the remote is configured correctly.
Select Advanced on the screen.
Select "Backup My Settings Now".
Verify that the purple gem is displayed beside the correct selection.
Select Next.
Select the type of backup to be performed:
Full system backup
Back up receiver settings
Back up remote settings
Select Continue twice to initiate data transfer. Maintain unobstructed LOS while the green progress bar fills.
Select Continue to resume programming.
Restore Receiver Data
Select Restore on the screen.
Teach Learning Commands
Receivers: 222k and 722k
Ensure the DISH Network remote control is programmed to the desired remote address to operate the DISH Receiver.
Place both the DISH Network remote and the original equipment's remote control on a flat, stable surface.
On the DISH Network remote, press and hold the mode button for your equipment for about three seconds until all of the mode buttons light up, and then release it. Your selected mode button will blink.
Select the type of learning you wish to perform:
Hybrid Mode
Press and release RECALL, then hold the RECORD button for about three seconds until the mode button is lit again. The button remains lit while learning.
Point the front of the original equipment's remote to face the small square (IR window) on the front left-hand side of DISH's remote. Remotes must be within 4 inches of each other.
On the DISH Network remote, press the button you want to teach.
On the original equipment's remote control, press and hold the button you want learned. If the DISH Network remote learns the command, the mode light blinks off and then back on. If the mode light blinks three times or remains lit, the DISH Network remote did not learn the command. You may need to press the button on the original remote several times for the DISH Network remote to learn the command.
After a button has learned a command successfully, repeat steps 3 and 4 until all commands you want have been learned.
To end the learning sequence:
Press one of the mode buttons on the DISH Network remote. This saves all of the commands for that mode and exits learning to return to normal remote control operation.
Normal Mode
Press and hold the RECORD button for about three seconds until the mode button is lit. The button remains lit while learning.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
when you select "new episodes" it will record ALL episoded that have not been recorded already. ALL episoded will record every time the show comes on. as far as then 134 hr recording, it sounds like a manual timer error i would erase it and monitor progress to see if it does it again.
Ocassionally these receivers have been known to do this. It is not an issue that normally repeats itself however it is very frustrating. The upside is it ussuaaly will result in 150 hrs of record time. If you did not receive the150 hrs delete all timers and recording and reboot the system. You should have the 150 hrs once it comes back online. Thanks for using Fix Ya.
Remove all the External Storage devices, make sure that you Un-Plug them Completely including their Power. After Resting the Dish Receiver, Plug-In everything back on and try.
Simply pry the battery cap off and remove the battery for at least 24 hrs. to depolarize the watch.And then reinsert battery and snap cover on.Your skin is back in order.Good luck.
