20 Most Recent Sony Ericsson Z310i Cellular Phone Questions & Answers
go to tmobile website for info
you need to text stretch 15 to 441 then you get a confirmation text back, then when you top up min of £15 you will get £15 the next week free. Once promotional £15 kicks in you have a week to use it or loose it. Promo used first and you get a text to say when its run out.
hope this is of some use
Sony Ericsson... | Answered on Jul 05, 2013
depending on the brand of your phone you usualy have a PC Phone Suite (or something similar named), connect your phone to the pc, open this Phone Suite and 9 times out of 10 you will have a feature called 'transfer contacts'.
Sony Ericsson... | Answered on May 28, 2012
You can get the unlock code here http://www.mobileunlocksolutions.com...-phone/rs1wp2/ and also get the unlock instruction in the same site....
Sony Ericsson... | Answered on Feb 01, 2012
Your mobile is locked with some network provider.
So whenever you insert a other network sim, your mobile displays the message like "Incorrect sim card" .
You can remove your network lock by using the codes. I found an unlocking service at Onlinegsmunlock.com . By using this you can unlock your mobile easily..
Sony Ericsson... | Answered on Dec 10, 2011
If it's a z310a (which it probably is, since a lot seem to have this screen problem) I can help you save your contacts to your SIM card so you can put them on a new phone.
To save contacts on a z310a that has a broken screen, do the following: 1.From standby, (make sure the backlight is lit up) press the center button once 2. Press down once to go to address book 3. Press center button to enter address book 4. Press RIGHT select button (upper right button with line through it) to select options. 5. Press down FIVE (5) times to go to Advanced 6. Press center button to go into Advanced 7. Press down FIVE (5) times to go to Copy To SmartChip 8. Press LEFT select button to enter 9. Press LEFT select button to select "Copy All" 10. Press LEFT select button to confirm. Wait a couple of minutes to make sure all your contacts were transferred.
Sony Ericsson... | Answered on Dec 04, 2011
Can't fix your phone, but can help you save your contacts to your SIM card so you can transfer them to a new phone.
Sony Ericsson... | Answered on Nov 30, 2011
chek your sim or change sim IC
Sony Ericsson... | Answered on Sep 25, 2011
Can't fix your phone, but can help you save your contacts to your SIM so you can put them on a new phone.
To save contacts on a z310a that has a broken screen, do the following: 1.From standby, (make sure the backlight is lit up) press the center button once 2. Press down once to go to address book 3. Press center button to enter address book 4. Press RIGHT select button (upper right button with line through it) to select options. 5. Press down FIVE (5) times to go to Advanced 6. Press center button to go into Advanced 7. Press down FIVE (5) times to go to "Copy To SmartChip" 8. Press LEFT select button to enter 9. Press LEFT select button to select "Copy All" 10. Press LEFT select button to confirm. Wait a couple of minutes to make sure all your contacts were transferred.
Sony Ericsson... | Answered on Aug 15, 2011
qand je mai le sim sa s'alime sa etind
Sony Ericsson... | Answered on Aug 12, 2011
you can either buy the unlock code online or you can call you service provider & they should provide you with the unlock code.
Sony Ericsson... | Answered on Aug 01, 2011
common problem of this phone is the flex connector that meets the upper and lower panel.flex cable are not repairable,indeed it can be replace with a new one.i think you need to bring your phone to a service center.it is more safe if somebody with knowledge will fix this problem,might broke or damage some parts and accessories.
Sony Ericsson... | Answered on Jul 24, 2011
To reset your Mobile Code Please Visit your nearest Sony Ericsson service center They will Reset it.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Sony Ericsson... | Answered on Jun 23, 2011
it would be best for you to just have the flexcable or LCD replaced.
Sony Ericsson... | Answered on Apr 28, 2011
not sure. Is calling another phone and getting it by reading the caller id not an option though?
Sony Ericsson... | Answered on Apr 06, 2011
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phones
Take care.
Sony Ericsson... | Answered on Mar 31, 2011
Sony Ericsson Z310i Cellular Phone Logo
158 questions posted
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Cell Phones
Most Popular Question
sony ericssion phon lock kode
  • Cell Phones
