Willnot communicate no spark
SOURCE: how to manually read abs
heres what you do put key in the ignition and you turn it to on position then off then on leave it on it will flash the codes to you you may have to do it three times i worked for dodge but been a while so memory off cue lil also dont let it kick starter any or wont flash codes hope this helps and if come back with codes can tell you how to fix it or why that code is going off hope this helps you
SOURCE: 2001 sentra no communication with scan tool
2001 nissan sentra gxe ecu not communicating, tried the fuse, fuse keeps blowing.
SOURCE: no communication from pcm to
Check fuses for power to the dlc. They used to hide it with the cigar lighter. It is best if you pull the fuses instead of using a test light. I have fixed problems just because the fuse lost contact in its holder.
