Dishwashers Logo
Sarah Klassen Posted on Jan 31, 2013
Where is the soap dispenser and jet dry dispenser on a Danby countertop dishwasher (with window)
There is a twist off cap in the door of the washer, which I filled with the soap, but the soap remained in there after cycle. Also I couldn't locate the dispenser for the jet dry, there is another spot beside the twist off cap, which is where I put it, didn't seem right, though.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 31, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
392
Points
0
I've got one of these countertop washers at home. The twist off dispenser you're talking about is for the jet dry (at least on mine) and there should be an area on the right side of the door for your soap. Hope this helps!
2 Related Answers
Anonymous
  • Posted on Aug 31, 2008
SOURCE: Dry Dishwasher Soap Still in dispenser after wash.
so here it is...
get a screw driver (you may need a "star" head driver as well), get in there and take out all that you can and clean it (it all comes out pretty easily)...you will find a lot of undisolved soap and hard water build up...rinse it, scrape it, vacuum it...just get out as much as you can...keep note of how you took it apart so you can put it back together...then put 1/2 to a whole gallon of vinegar in and run a cycle (hi-temp if you have that option)...if it was like mine most of your sprayers were gummed up and the water just wasn't moving through the machine...
to avoid this problem...use half of what you have been using of your detergent...and only fill the "pre rinse" section if you are doing pots and pans....and then only fill that half way as well.
after that run a few cups of vinegar through on an empty cycle once a month...
whole job (not including the wash cycle) 1.5 hours...
Anonymous
  • Posted on Mar 14, 2009
SOURCE: Whirlpool Gold Quiet Partner IV issue with soap dispenser
This happened to me as well. I think I solved the problem. It started when I first lowered the top rack. In doing so, the door doesn't open all the way. It also won't open all the way if your cutlery rack is in the front and you've put large utensils like a spatula. Consequently, detergent dried under the latch and it wouldn't firmly catch. For months I put up with it never emptying completely. The other day I took a tooth brush and very hot water and cleaned under the latch. After, I could feel a difference in the way the latch operated (with greater pop on opening). So far its been doing fine. Hope this helps.
Denise
Trying to find out where to put the soap in my danby countertop dishwasher
It go’s in the soap dispenser located inside the door. Be sure to close it’s lid after adding detergent.
2answers
My Danby countertop dishwasher won't wash-the dishwasher detergent is never used at the end of the wash and nothing is clean
Was it working before, and now has stopped working? If so, it sounds like it has poor water circulation. It might be caused by a leak. If you have not noticed a leak, it might be clogging due to hard water deposits. Do you live in a region with hard water?
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Soap not breaking down in dishwasher
Be sure to run kitchen water hot at faucet before starting dishwasher or you will get an entirely cold water washer. Also be sure the jet dry dispenser is not empty. Only use liquid jet dry. Pay no attention if soap says with jet dry. Does not work as well. Hope this helps.
4helpful
WHERE DOES JET DRY GO
the turn nob is a cap that you screw out and pour your jet dry liquid in then replace the nob/cap the jet dry will be dispensed automatically.
I can't fill the rinse aid. I do not have a
open the door and where the jet-dry indicator and dispenser is just turn the cap and once removed fill the jet-dry in that location if it a large bottle of jet-dry it will only take about 1/3 to 1/2 of the bottle
6helpful
Where do I put the Jet Dry in my Bosch Sensotronic? I bought a house with this dishwasher but no manual. Many thanks!
ON SOAP CUP WITH DOOR OPEN LEFT HAND SIDE IT WILL HAVE A DOOR IT OPENS LIKE A TUPPER WARE BOWL FRONT TO BACK LEFT HAND SIDE OF SOAP CUP LIFT UP AND SLOWLY POUR 3 OZ OF JET DRY OVER DIAL INDICATOR MAKE SURE YOU POUR SLOWLY MAKE SURE YOU CLOSE THE DOOR CLOSE D/W AND REOPEN DOOR THIS BURPS THE DISPENSER. JET DRY IS NOT SOLUBLE IN WARM WATER SO IF YOU SPILL ANY TAKE A RAG AND CLEAN IT UP GOOD ONEC A MONTH YOU REFILL W/ 2 TO 3 OZ
dON
262-893-4840
Kenmore Elite soap door problem
Dispenser may be bad. Push the hi-temp button , air -dry, hi-temp, air-dry in that order. All lights will lite up and this will do test cycle of all components. If soap disp opens then soap tab may be the issue. I have had intermittent dispenser issues and they are often hard to solve as other components may be at fault.
2answers
i would think the drain hose from the unit is leaking from the description you give.let me know
3answers
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Top Danby Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
