Brand new vinotemp wine fridge. If i set it to 58 degrees, it holds to 62 degrees. if i set it to 62 degrees it holds to 65 degrees. and when it tries to get cooler, it makes a loud whirring sound, reaches the colder temperature and then slowly gets warmer again and holds on the warmer termperature where it remains silent.
SOURCE: VinoTemp VT28TEDS - circuit board
Here is the phone number for Vinotemp International 800-777-8466 for customer service.
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
SOURCE: Do you carry the thermostat for vinotemp wine
You can purchase replacement parts for virtually all Vinotemp coolers directly from Vinotemp. Some parts are listed/available on Vinotemp.com (http://www.vinotemp.com/Browse.aspx/446/Replacement-Parts) But otherwise, just give their service department a call or shoot them an email and you can confirm the part number and purchase the required part.
SOURCE: i have a vinotemp VT-12TEDi
The thermostat may be bad. Test it with multimeter set in "ohm" to confirm that is defective before replacing.
