I tried charging the battery, but it still won't allow me to take a picture. It worked fine yesterday, but for some reason won't today. Any ideas as to what that error message means?
TIA !
This error indicates the following:
This card cannot be used (CHR) blinks.
Problem(s)
Error accessing memory card
Unable to create a new folder (on card)
Card has not been formatted for use on D70
Try another card
Format the card using your D70 (all images will be erased)
Check the card for visible damage or poor contacts.
You may have inserted a memory card that was been used in a different camera or the formatting process did not complete successfully.
I hope this helps.
I have a nikon D70 and it worked fine now i get this same error message CHA and can't get it to work please help
Couple years back got CHA fault coming up now and again...removed card, put it back it, worked for a while...then one day it did not and I ended up reformatting it, losing a few pics in the process.
Card was new and never put into a different camera.
Problem went away for while and is now back and I can't get CHA fault to disappear despite reformatting it, a couple times.
Took it into a shop, we inserted a new SD card, formatted it, but still CHA fault would not got away...so unsure as to what to do next
