LG WM-2277HW Front Load Washer Logo
Posted on Jan 29, 2009
Lg intello washer error code cl
Hi my lg intello washer 7kg will not come on it displays error code CL in panel and wont operate please can you tell me what this means thnx
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Feb 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
67875
Points
25
Fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
  • Karen Berry
    Karen Berry Feb 27, 2023
    I have the same problem but I hold the two child lock buttons as suggested, but it does not unlock! Any other suggestions please??
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
How do I clear the CL code on the display of the washing machine lg intellowasher 7kg WD-12235FB
The Child Lock function on your washer has been enabled. Press the options buttons simultaneously for 3 seconds to reset.
1helpful
I have a LG Front loader machine, WD-10485TP displaying CL error code. Please help.
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it. It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
If problem remains unresolved, revert and i would tell you few more methods.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
2helpful
It showing cl on the screen
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for a 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds.
If this doesn't work then try pressing "options & select" till the light goes off.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
8helpful
3answers
TROMM Washer "CL" Error Message
THE CL ERROR CODE IS CHILD LOCK, PRESS AND HOLD THE PREWASH BUTTON FOR 3 SECONDS AND IT SHOULD TURN OFF........ BUT IF THERE ARE OTHER BUTTONS TO PRESS TRY IT OUT, THE OLDER LG'S HAD TWO BUTTONS TO PRESS, SO IF YOURS ARE THE OLDER ONES TRY IT OUT..... IF THIS HELPED OUT, PLS LEAVE A FEED BACK. I DO NOT ACCEPT PAYMENTS FROM ANYONE ONLY FEED BACKS, IT MOTIVATES ME TO HELP OUT OTHERS WHO NEEDS HELP....................
2helpful
LG intello washer WM1285FHD The code CL is on display how do i clear and get machine to work?
CL == Child Lock.
Press "Wash" & "Rinse" buttons simultaneously to set / clear.
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
14helpful
2answers
LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
239helpful
8answers
LG WM-1285FHD Error Code 'CL'
The "CL" code is not an error! This means "Child Lock"!
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
And happy day will come! :))
5helpful
LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
