Error code c4101
SOURCE: Error code c4101
code c4101 This is Polygon motor's code, this code will not reset from the panel, you have to call the technician, he will check the polygon motor, if needed then he will replace the motor. polygon motor is located in LASER UNIT.
SOURCE: error code c4101
I repaired the polygon motor just by putting oil in it, so I didn't have to replace any part. Try it before replacing parts !
