Kitchen Ranges Logo
Andrea DiFilippi-Staley Posted on Oct 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gas oven turns off on its own
Power failure causes oven to turn off during cooking, or oven turns off while cooking and causes power failure. The timer is not set, and the oven temperature seems to make no difference. Whether the temp is set to 275* or 450*, the oven can turn off at any time. No rhyme or reason to it. Have no problems with the stove, just the oven.
NOEL
Level 3:
Top Expert:
  • Master 8,606 Answers
  • Posted on Oct 27, 2017
NOEL
Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322449
Points
68630
5 Related Answers
Tech007
Ronald Rousseau
  • 63 Answers
  • Posted on Aug 29, 2007
SOURCE: Tappan TGF336ASD stove Calibration of the oven
does it have a knob in front or is it a panel to operate bake broil ? if it has a oven knob take it off and look in the back of the knob you adjust it there if it is electric if it is gas you need to use a small screw driver in the stem where the knob goes on and turn a little screw in there to ajust temperture turn clockwize to adjust temp up
Anonymous
  • 146 Answers
  • Posted on Dec 21, 2007
SOURCE: Gas oven not heating to temp
You more than likely have a defective oven sensor. For some reason the sensors tend to go after a few years of use. It is in the upper right or left hand corner and looks like a probe sticking through the inside back of the range. When you open the door you just look towards the top back left or right corner there are 2 screw securing it to the back. Gently pull it forward. You will see a couple of small wires feed into as you pull it in. On most you will see a plug in connector come through the hole if not you may have to just splice the new one in.
Anonymous
  • 131 Answers
  • Posted on Mar 10, 2008
SOURCE: Tappan Oven overheats!!
If you have electronic controls, you'll need either the temperature probe (about $60.00) or the clock (about $150.00). You can test the temperature probe from behind the machine. It should read about 1080 ohms at room temperature. if the probe is good, replace the clock.
If you have mechanical oven controls, you need a new thermostat. Is the too high temp consistent? (i.e. runs at 375F +/- 25F?) If so, you can usually adjust the thermostat **** to read closer to the actual temperature.
Anonymous
  • 725 Answers
  • Posted on Aug 25, 2008
SOURCE: Oven Failure Code F1
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
to fix your F1 error
92028 RELAY PCB, 105 C
Anonymous
  • 360 Answers
  • Posted on Feb 08, 2009
SOURCE: How do I calibrate the oven temp?
Oven Temperature Adjustment Option for the MSG5770
If you think the oven should be hotter or cooler, you can adjust
it yourself. To decide how much to change the oven temperature,
set the temperature 25°F higher or lower than the temperature
in your recipe, then bake. The results of the “test” should
give you an idea of how much to adjust the temperature.
To adjust the oven temperature:
1. Press the BAKE pad.
2. Enter 550° by pressing the number pads “5, 5, 0”.
3. Press and hold the BAKE pad for several seconds until 0°
appears in the display.
4. Press any number pad to change the temperature. Each time
a pad is pressed, the temperature changes by 5°F.
• Press repeatedly to reach +35°F. Continue pressing
to reduce the temperature up to -35°F.
• If the oven temperature was previously adjusted, the
change will be displayed. For example, if the oven
temperature was reduced by 15°, the display will
show -15°.
5. When you have made the adjustment, press the
CANCEL pad and the time of day will reappear in the
display. The oven will now bake at the adjusted
temperature.
NOTE: Do not change the temperature setting more than
10° at a time before testing the oven.
It is not necessary to readjust the oven temperature if there
is a power interruption. This adjustment will not affect
broil or clean temperatures.
HOW TO LIGHT OVEN WITH A MATCH
Look up product manual on internet.
Look at label located inside oven door, and add .pdf to search parameter to help find manual.
Then read section about lighting appliance.
If power is out, then pilot will not have any gas >> if gas control is electronic.
Many electronic gas controls require electric power to operate circuit board.
In old days, you removed the bottom tray on oven to access burner and pilot orifice. Then you pushed down switch to release gas through pilot tube, and put lit match into the gas stream to light pilot. Hold down switch until pilot flame heated tip of thermocouple which caused magnetic switch to stay open inside gas control. Release switch and pilot stayed lit.
Safety concerns and vast advances in manufacturing cheapness have changed gas appliances so they are more inconvenient for do-it-yourselfers during ordinary power outage.
Cook hamburger over metal bucket with newspaper, and grease on newspaper burns enough to cook hamburger.
People always buy generators and flashlights, but nobody suggest buying barbeque briquets and starter fluid as way to keep warm and cook.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2answers
sir what type of oven u r using???
Whirlpool gold single oven - YGBS277PDB7 - The power failure signal has started to show up during cooking and everything shuts down even though there is power. what part would need replacing?
Turn the breaker off before you start. To isolate this your going to need to remove the oven from the wall. Once done, you'll need to remove the top of the oven so you can see down inside of it. Starting at where the wires come into the machine, you're going to trace the wiring to each of the parts in series. These parts include the thermal fuse, lock mechanism, wiring, etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
1helpful
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
1helpful
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
Oven resets (like power failure) frequently - either while pressing buttons or while cooking food. Approx 5 yrs old - problem just started.
Hi.
The following parts may cause this problem and must be tested:
Control Pad: This is most likely the problem , testing the contol pad is quite complicate.
Door lock: A defective door lock can cause the magnetron and turntable motor being turn off erratically. This wont cause the program to reset.
Power cord and power connection solder joints: this can cause a microwave restarting because vibration caused by the oven working cause power interruption.
A bad shielding to controller board can also cause the microwave resetting because of the interference caused by magnetron on control board circuits. This is also quite common.
The control pad or control board are the parts that are most commonly causing this problem.
4helpful
Microwave oven turns off
It could be an overheating magnetron. There is a thermostat inside (mounted to the side of the magnetron) which senses excessive heat and opens up, disconnecting the power to the oven. If that's the case, unplugging it and plugging it back in will not fix it. It will come back on by itself after it cools down. That's another indication that it might be a thermostat kicking out. You might try to further characterize the failure: - happens only when cooking on full power? - also happens when cooking on a low power level? - shuts down every time you use it? - only shuts down after XX amount of time cooking? Once you characterize it more, I can make further suggestions. It may also be a bad connection on the control panel.
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
