20 Most Recent Whirlpool GS440 Gas Kitchen Range Questions & Answers
Whirlpool estate electric range model heat oven
there is also a temp sensor inside the oven that could be faulty
9/19/2013 6:00:01 PM • Whirlpool GS440... • Answered on Sep 19, 2013
Oven stops heating during cooking
Heating element
6/18/2009 3:57:49 PM • Whirlpool GS440... • Answered on Jun 18, 2009
I have an approximately 15 year old Whirlpool Acubake glass top stove/oven. One of the elements is not working. Are there on board fuses/circuit breakers that can be replaced or reset?
If you disconnect it from the mains supply and this may help; https://www.google.com/search?client=firefox-b-d&q=Whirlpool+Acubake+glass+top+stove%2Foven#fpstate=ive&vld=cid:a30276c9,vid:gFNJHpEvCc0,st:0
4/14/2024 3:51:19 PM • Whirlpool... • Answered Yesterday
2answers
How to reset a Whirlpool range with a PF code ? model GY396LXPB01
The link below goes to the Whirlpool site that gives instructions on how to reset your oven. Hope this helps. https://www.whirlpool.com/product-help/error-code-on-the-range-or-built-in-oven-display/PH3756/
1/25/2024 3:36:47 AM • Whirlpool... • Answered on Jan 25, 2024
My whirlpool electric range is in a very "roach infested house." Could they have made my oven fail and beep all day?
Yes they could. You need an exterminator to get rid of them. They are filthy creatures and you should not be cooking in there.
1/17/2024 9:17:22 PM • Whirlpool... • Answered on Jan 17, 2024
Why would a Whirlpool range Model # W10432689A come on by itself and the digital numbered area come on also, go off, and a clock appear there?
Check the power input wiring to be sure it's good (no loose or burned connections or corrosion). However, this is most likely a controller board failure. It may be a bad electrolytic capacitor on the controller board, but I've seen a couple with intermittent faults like this that are impractical to diagnose without internal service documentation. That isn't given to field service techs; they're just told to change the controller module.
9/3/2023 6:56:40 AM • Whirlpool... • Answered on Sep 03, 2023
Whirlpool GFE471LVQ0 electric oven. Broiler stays on in bake mode
Disconnect the mains power for 15 minutes to try and reset the control boards. It may be that the bake switch is faulty. Call for service.
1/25/2023 3:58:59 AM • Whirlpool... • Answered on Jan 25, 2023
Whirlpool gas range diagnostic code E6 46 (cannot find this error code combination anywhere)
E6 46 is a diagnostic code for a Whirlpool gas range. This code indicates that there is a problem with the oven temperature sensor. The sensor measures the temperature inside the oven and sends this information to the control board. If the control board detects a problem with the sensor, it will display the E6 46 error code. To troubleshoot the problem, you'll want to do the following:
  1. Check the wiring: Make sure that all of the wires connected to the oven temperature sensor are secure and not damaged.
  2. Check the sensor: The oven temperature sensor is located in the back of the oven, near the top. Make sure that the sensor is properly seated in its socket and that it is not damaged.
  3. Check the control board: If the wiring and sensor appear to be in good condition, the control board may be the cause of the problem. You'll want to check the control board for any visible damage or loose connections.
If you are unable to find the problem, I recommend having a qualified repair technician diagnose and fix the issue for you. Electrical issues can be complex and it's important to address them promptly to prevent further damage.
1/8/2023 1:32:12 AM • Whirlpool... • Answered on Jan 08, 2023
What is F9 code for whirlpool stove
The F9 error code on a Whirlpool stove typically indicates a problem with the oven temperature sensor. The oven temperature sensor is a device that measures the temperature inside the oven and sends this information to the control board. If the sensor is not functioning properly, it can cause the control board to display the F9 error code.
To troubleshoot the problem, you can try the following steps:
Check the oven temperature sensor: Make sure the sensor is securely connected to the control board and not damaged. You can also check the resistance of the sensor using a multimeter to see if it is within the specified range.
Check the wiring: Make sure all the wiring for the oven temperature sensor is securely connected and not damaged. Check for any frayed or damaged wires, and repair or replace them as needed.
Check the control board: If the oven temperature sensor and wiring are in good condition, the problem may be with the control board. You can try resetting the control board by unplugging the stove and waiting a few minutes before plugging it back in.
If these steps do not resolve the issue, you may need to take the stove to a professional appliance repair shop for further evaluation and repair. They will be able to diagnose the problem and recommend the necessary repairs.
12/24/2022 4:37:31 PM • Whirlpool... • Answered on Dec 24, 2022
2answers
Display gone blank, stove top works, no way to turn on oven, no lights or indicators illuminating? Hoping for a fuse, not control panel replacement
The fuse is your breaker. There may be a fuse hiding under the control board display but unlikely. It is likely to be the control panel itself. I would suggest dealer service as they are expensive, need correct diagnosis and warranty on the part and the replacement labour.
12/6/2022 2:02:20 AM • Whirlpool... • Answered on Dec 06, 2022
Whirlpool range SF362LXSS0 replaced both igniters and still oven won't turn on
All Gas Ovens can be fixed, but the should be serviced by a registered gas technician. The spark igniter is only one part of the lighting procedure, they also have a thermocouple, which is a safety device that open the main gas valve once certainly criteria are met usually a pilot light flame. The parts schematic shows the gas valve and it is $181. I don't see a safety thermocouple. https://www.searspartsdirect.com/model/2v56d5n3jv-001198/whirlpool-sf362lxss0-gas-range-parts This is the part that is likely to have failed, but I am reluctant to suggest you change it on my say so. Pay the extra $75 for a qualified technician to diagnose and replace. It has electrical contacts, so the fail safe is probably inside and is dependent on the spark igniter being fully functional. https://www.searspartsdirect.com/product/5w6dsrlw7b-0022-664/id-9761959 ..
2/13/2022 8:55:30 PM • Whirlpool... • Answered on Feb 13, 2022
I can't find wfe535s0jz0 Wiring Diagram? Help
normally on inside electrical cover
1/6/2022 1:24:59 PM • Whirlpool... • Answered on Jan 06, 2022
2answers
Whirlpool gas stove burner knob is loose
You should be able to pull the knob straight out. Don't lose the internal sleeve. Here is a quick DIY video. https://www.youtube.com/watch?v=NSChe0uwRvA Or you can put some Loctite glue in the cracks on both sides before you tighten the zip Just to strenghten this in case it gets bumped again.
1/4/2022 6:16:23 PM • Whirlpool... • Answered on Jan 04, 2022
2answers
We had a power outage and after the power cut back
if range uses electric.check fuses,and reset breaker.make sure proper voltage is going to the range.
10/28/2021 6:18:15 PM • Whirlpool... • Answered on Oct 28, 2021
Whirlpool GS440 Gas Kitchen Range Logo
Popular Tags
5 questions posted
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Kitchen Ranges
Most Popular Question
whirlpool estate electric range model
  • Kitchen Ranges
