Amana GMH950453BX Gas Furnace Logo
A
Anonymous Posted on Jan 22, 2013
Amana AMH95 Blown control fuse
Keep blowing 3amp control fuse
Gary Grider
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 21 Answers
  • Posted on Dec 09, 2014
Gary Grider
Contributor
Level 1:
Welcome Back:
Answers
21
Questions
0
Helped
7218
Points
29
Control fuses only blow with a 24 volt problem. Make sure that you replace it with a fuse NO LARGER than 5 amps.You could have a thermostat wire pinched or some wire touching the cabinet inside the unit, but it is a 24 volt problem.
3answers
I have a goodman gms90703bxa furnace, transformer started smoking and control board has no red light on. I am suspecting a bad control board??
I would suspect bad transformer. The board may not have a light because it is not receiving low voltage from transformer. With a multimeter you can test the transformer. But, since you likely have a short somewhere be sure to install a fuse right after the transformer or you will be burning up another transformer until you figure it out.
I have 2 zone gas hot water heat. When I turn 1st floor zone down to 60 degrees and 2nd floor zone up to 80 degrees why do I get heat on 1st floor.
Gas Furnace
If you are looking for a high efficiency furnace with up to 96% efficiency then Amana AMH95 forced air gas furnace is a considerable furnace for you home heating requirements.
- See more at: http://www.cleanairheat.ca/amana-amh95-gas-furnace.php#sthash.FeFfEH9f.dpuf
I have a duo therm model 57915531. i have checked the breakers all the fuses and the thermostat. i have found a 3 amp fuse in the control panel of the roof unit. this fuse was blown. i replaced it and it...
That unit has a thermostat I believe and 12 or 24 volts to power it. The 3 amps tells me it may be either line or low voltage, see manual. the fuse blows due to a short in the control circuit, a transformer if low voltage.
My Amana package system fan only blows cold air
a fuse blows for a reason. dry bearings will increase amp draw, a non rotating fan rotor will blow a fuse. burnt windings will almost instantly blow a fuse. just changing the fuse may not solve your problem. find the problem and fix it THEN replace the fuse.
York AC blown 3 amp fuse how do I replace?
the fuse is for low voltage 24v wires it is most likely located on the control board inside your furnace or air handler most of the time it will look like an automotive fuse there is probably a reason why its blowing usually a pinch or short in the wire if its a re accuring problem you might want to get a resetable 3amp fuse or popper i would be more concrned about calling the company and saying you charged me and never fixed the problem
Heat worked fine all winter. Turned on A/C and blew a fuse. Replaced 3amp fuse and worked for a few minutes and blew another fuse. Checked all connections, filter, obstructions, need help...
If your blowing fuses then you have something grounded or shorted. By grounded I mean a wire has come loose and is touching the cabinet or a part that allows it to go to ground or your motor, capcitor or compressor is shorted.
2helpful
2answers
Blowing 3amp fuses
You have a low voltage short. A lot of low voltage shorts come from the wires that go out to the outdoor unit. Go outside and inspect those wires and that they are in good condition. Also check for any splices in those wires that they haven't degraded in any way. This is the only thing that will blow the fuse. That's why it's only 3 amps and based on the size of your fuse, it's a gas fired unit right? Have a great day!
2helpful
My fuse from the controller keep getting blown out.
With all due respect, there is some rather incorrect information in your response Jidza.
These washers are direct-drive and do not have any transmission, nor does the motor "spin backwards during extract". I think you are confusing a Fisher Paykel machine with conventional motor-driven washers. The "motor" is not a self-contained unit, it is really a "drive unit" consisting of a stationary stator/RPS sensor and rotor that either spins in a circular motion to drive the basket for the extract cycle, or it will "pulsate" to mimick the action of a transmission for the agitate cycle. There is no belt or gears or any of that. It's a brilliant design that eliminates many of the moving parts on the typical American washing machine.
With that said, in regards to the original post, the diverter valve, water pump and water inlet valves all are possibilities for a popped fuse in the controller, as well as a fault in the circuitry in the controller itself. Visual inspection of the pump or a simple continuity test is not enough. You need to check the specific resistance of the coil for the water pump, as it can be out of spec and cause the control to fail.
Some of the other experts do not approve when some of us suggest that obtaining a service manual would be the best cause of action but in this case it is warranted. These machines are not like "conventional" washers, they are, for the most part, electronic in nature and proper understanding of the circuits involved in the various cycles and functions makes servicing them much easier and your chances of sucess in repairing them much greater. You can obtain a detailed service manual for the GWL11 here:
http://www.fisherpaykelparts.net/ecart/category.php?category_id=53
My answer is not intended to insult anyone, I'm trying to help the original poster.
The whole system won't turn on
Go to Logitech support and check the faq's on your speakers. You must replace with the same fuse and it may be a 3amp slow blow fuse. If so replace with the same fuse or you will just keep blowing them out.
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
