Broken lovejoy connector
You have to take the cabinet off first, that can be done by removing the control panel screws, hinge it back and then you will find 2 brass colored brackets that hold the cabinet to the base frame. remove them and the wiring harness from lid switch. the cabinet will pull off at a 45 degree angle from the base.
remove the 2 clips from the pump, on the front of the motor, and then 2 screws hold 2 clips onto the motor, remove the clips and that will let the motor loose from the transmission plate.
this will allow you to replace the "drive coupler" that is most likely what you need to replace.
part number 285753a from whirlpool. about 15-20 bucks.
Hello
& Welcome to FixYa
Please
view the video for step by step instructions on transmission replacement:
Please
get back to me if you have any other questions.
Kevin
