Konica Minolta bizhub C250 All-In-One Laser Printer Logo
aileen panal Posted on Jan 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
P-21 error of c250 - Konica Minolta bizhub C250 All-In-One Laser Printer
Tech Bravo
Level 2:
  • Konica Minolta Expert 337 Answers
  • Posted on Jan 30, 2013
Tech Bravo
Level 2:
Answers
337
Questions
0
Helped
159925
Points
449
P-21: Color regist test pattern failure
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
SERVICE ERROR CODE
I am trying to find what that code means. If you want to look for yourself, there are tons of C250 manuals at the following link at Minolta.
http://kmbs.konicaminolta.us/content/support/supporthome.html
Pick category: Office systems
Pick model: C250
8650 machine error 21
4 Change PRCB.
Hope fully not the last two expensive.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error C-D36F apear in my minolta c250
NVRAM problems better calll KM tech because this kind of error codes need specialez tech and procedure like NVRAM data recovery etc
2helpful
What is error p-21 of konica minolta bizhub c250?
4 Change PRCB.
3answers
P-21 and p-5 error message. and fully cyan color comes.
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
2answers
ERROR CODE SC45-20 MINOLTA 500
Color registration problem Restart copier and leave the front door open,will bypass the error code page.Press HELP,then press KEY OPERATOR MODE, scroll down to 21 EXECUTE ADJUST OPERATION, select COLOR REGIST AUTO ADJUSTMENT, then press OK, PREVIOUS SCREEN. After adjusting, it will back to normal. If the code number back on again, then it was the transfet belt off alignment. If you know how to pull the transfer back to center position, problem solve, if not, call technician.
2helpful
Error code C-D351 on a Bizhub C250
are you sure that you have a correct model and malfunction ccode ??? i cant find this code on bizhub C250
Sansa c250 unable to sync music from WMP11
The certificate must be obtained by syncing the device to the music service from which you obtained the songs.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
