Logitech LS-21 2.1 Speakers Logo
Kathleena Le Posted on Jan 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an HP Laptop with Windows 7 and I have correctly set up my Logitech LS21 speakers, but the volume control does not enhance the sound coming from my laptop. The speakers work fine, but the sound is low and it doesn't seem as if the volume control works. My soundcard is working fine as well. I am unsure on how to fix this.
Michael Green
Level 3:
  • Master 3,799 Answers
  • Posted on Jan 21, 2013
Michael Green
Master
Level 3:
Answers
3799
Questions
0
Helped
600430
Points
10177
There are 2 volume controls on the audio output in windows 7. one is the system volume the other is the device volume. make sure that they are both at full and then control the sound volume on your speakers.
5 Related Answers
Anonymous
  • 2985 Answers
  • Posted on Jul 24, 2007
SOURCE: Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
A
Anonymous
  • Posted on Jan 01, 2008
SOURCE: No sound
Make sure you've got your V20's set as the default sound playback device.
Control Panel -->
Sounds and Audio Devices -->
Tab 'Audio'; select 'Logitech USB Speaker' in the dropdown list in the first item on the tab.
just a thought...
A
Anonymous
  • Posted on Jun 19, 2008
SOURCE: Speakers not working correctly
you need to activate speaker fill i the settings
Anonymous
  • 827 Answers
  • Posted on Dec 23, 2008
SOURCE: How do I connect my Logitech X-540 speaker to my laptop an
I just opened my Realtek HD Audio settings and clicked on 5.1 sound.. then assigned the different ports.
Make sure you have the latest audio driver update for your soundcard, and go through the software options, it'll be there somewhere..
If you think you might have a RealTek soundcard, you can find newest Realtek HD audio drivers here:
http://rapidshare.com/files/173930788/Vista_R211.zip
Has XP support too. Install and reboot, then the 'red' realtek volume icon should appear in the bottom right hand corner of the screen.
You'll find the settings manager in there.
Good Luck
Chris (ziraffa)
Anonymous
  • Posted on Mar 31, 2009
SOURCE: Logitech x-540, front right & left speakers not working
Turns out my soundcard wasn't fully inserted into the motherboard, so I just took it out then put it back in and everything works fine.
Plug my speakers into my laptop, tried to play some music from youtube and no sound comes out of speakers (only laptop speaker). Look at changing the settings but still nothing. Please HELP!
you might need to select external speakers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
hope this helps
2answers
I just bought the LS21 logitech speakers, and i plugged them in fine, but when playing music or watching a video the only sound that comes out is from the left speaker and not the others. My computer is...
click start control panel hardware and sound manage audio devices playback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further changes to your sound setting by right clicking on the speaker icon in the taskbar(bottom of screen)
hope this helps
I cant make my speakers work. logitech LS21 Win 7 HP model:p6755a
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
When i play music, the sound would come out from one speaker only. the audio jack seems to be fine, but do not know what is wrong. my model in logitec LS21
Hello
Try going to control panel,audio,settings.Make sure your speakers are set to 5.1 surround sound.
Next if there is software for these speakers or your audio device be sure it is also set for surround sound.
1helpful
Logitech LS21 speakers connected to HP slimlie s5730f - barely any sound, volume adjustments make no difference. Doesn't recognize Logitech speakers under device manager.
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
don
Hi I just reconfigarated my pc and now it wont recognize my logitech Ls21 speakers i can't find the problem why it's not working do u have to install a program or something ....
also
hope this helps
No sound coming from speakers but coming from laptop
Go to your control panel from the start menu.
Select Sounds Icon. Here you will find a list of "installed" and built-in speakers. You need to select your newly installed speakers, and calibrate them (or test) them.
It is all right there in the Sounds Control Panel.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
(also, try restarting the computer and make sure all volume resources are not muted, and are turned up enough)
48helpful
11answers
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
