20 Most Recent Logitech LS-21 2.1 Speakers Questions & Answers
Hi, you need to check for problems with your sound driver. To do this go to start, control panal, system, then hardware and finally device manager. If there is a problem your audio device will be highlighted with a yellow ?. You will need to down load and install the latest sound driver for your system. If you are not sure which one; you can do a google search, or try the Realtek AC'97 sound driver, which is free to down load from a google search.
Hope this helps.
Logitech LS-21... | Answered on May 24, 2014
There are 2 volume controls on the audio output in windows 7. one is the system volume the other is the device volume. make sure that they are both at full and then control the sound volume on your speakers.
Logitech LS-21... | Answered on Jan 21, 2013
Try using an earphone on the system, if it works properly ( that is if the sound is good and normal) than probably your sound IC needs to be replaced as it is wearing out.
G.
Logitech LS-21... | Answered on Dec 07, 2012
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
right click on the speaker icon in the bottom taskbar select playback devices make sure it has a green tick and the correct speakers are selected
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps you W7
Logitech LS-21... | Answered on Mar 22, 2012
I think that the square shape one might fit the sub woofer.
Thanks
G..
Logitech LS-21... | Answered on Nov 02, 2011
PLease be more specific...thanks
G.
Logitech LS-21... | Answered on Oct 27, 2011
i found i needed to down load a different driver on the computore so i could hear anything
Logitech LS-21... | Answered on Sep 09, 2011
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Logitech LS-21... | Answered on Sep 07, 2011
click start control panel hardware and sound manage audio devices playback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further changes to your sound setting by right clicking on the speaker icon in the taskbar(bottom of screen)
hope this helps
Logitech LS-21... | Answered on Aug 25, 2011
click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
you might need to select stereo speakers
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try swapping the speakers around if the problem still persists either the speaker is faulty
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps you
Logitech LS-21... | Answered on Aug 20, 2011
Improve the Fixya.com experience for everyone by voting!
The user manual has color set-up diagrams. Click on the following link for a copy of the current user manual and all the pertinent information.Official Logitech LS21 2.1 Speaker User/Installation Download
All the best,
Ben
Logitech LS-21... | Answered on Jul 21, 2011
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Logitech LS-21... | Answered on Jun 16, 2011
also
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Logitech LS-21... | Answered on May 19, 2011
Hello
Try going to control panel,audio,settings.Make sure your speakers are set to 5.1 surround sound.
Next if there is software for these speakers or your audio device be sure it is also set for surround sound.
Logitech LS-21... | Answered on Apr 25, 2011
YES YOUR SOUND DRIVER IS NOT ISTALLED .
YOU ALSO USE THE INTERNET YOU DOWNLOAD THE NEW VERSION OF REALTEK SOUND AUDIO DRIVER AND THEN SOUND IS OPEN.
Logitech LS-21... | Answered on Apr 10, 2011
There is no additional software for your speaker system I went to logitechs website and checked for you. Here is their link to your speakers either click on the link I am sending you or copy and paste it into your web browser.
http://www.logitech.com/en-us/439/4251?section=downloads&WT.ac=sc'downloads''dd
Your only adjustment to your speakers is if you right click on the speaker and choose what you want to adjust from the pop up menu that comes up.
I hope this helps you out if it did please leave me a Yes that you were helped. Thank you
Logitech LS-21... | Answered on Apr 05, 2011
Logitech LS-21 2.1 Speakers Logo
59 questions posted
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
am running vista 32 bit dell computer
  • Audio Players & Recorders
