Samsung SyncMaster 204B 20.1" LCD Monitor Logo
Lbuonome Posted on Jan 20, 2013
I have a Samsung LED computer monitor (model S23A300B). The monitor connects to my Macbook air. The Samsung monitor recently stopped showing the picture on my laptop. Instead, red, green, blue and white horizontal stripes flash on an off of the screen. Any help? Is this fixable?
Andy
Level 1:
  • Contributor 262 Answers
  • Posted on Sep 11, 2013
Andy
Contributor
Level 1:
Answers
262
Questions
0
Helped
56785
Points
28
I have the identical monitor to you, and the identical symptom; it flashes red/green/blue/white, then white, then bright white, then black. Through a combination of luck, insight, observation and brilliance, I discovered that it's something broken with the analogue input that puts it into a test mode of some kind. I switched to the digital input, and it works fine. I think the same would happen for you.
Bruce Wilmot
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jan 20, 2013
Bruce Wilmot
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
15482
Points
28
Try the plugging the setup into a different monitor to eliminate the lead however it sounds like the monitors died. With cost of screens even if you can get hold of one you'll be better off getting a new monmitor.
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Dec 30, 2006
SOURCE: Pink horizontal stripes on my monitor
If youve tried pressing the degaus button on the monitor and the same result then either your graphics driver is corrupt and needs to be updated from the manufacturer web site or the monitor is on it's way out. Try a friends monitor on your system or your monitor on a friends, if it's the same on a friends ststem, it's a belated Xmas present for yourself.
Anonymous
  • 709 Answers
  • Posted on Oct 10, 2007
SOURCE: Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Anonymous
  • 89 Answers
  • Posted on Aug 24, 2008
SOURCE: Samsung Monitor Syncmaster 913V Montior Screen shows patches of screen on desktop and playing videos
try to reset the monitor to its default settings.
SamsuTech
  • 113 Answers
  • Posted on May 10, 2010
SOURCE: Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Anonymous
  • Posted on Jun 26, 2010
SOURCE: Samsung 953BW monitor. Blue light is flashing but no picture.
hi, i have the same problem...any solution?
My Mac air will turn on but it turn off automatically in few seconds
Try first an SMC Reset:
SMC reset
  1. Shut down the computer.
  2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
  3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
  4. Release all the keys and the power button at the same time.
  5. Press the power button to turn on the computer.
    Note
    : The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
    If this does not work then you need to take it to your seller or to an Apple store for them to check it out. You are probably out of warranty judging from your model number so not much they can do.
How to set up and connect to macbook
find the jack on side of MacBook- look for same jack on tv- get cord and plug it in- tv to pc mode and mac should send signal to tv
HELP! bought a BX2450 Samsung monitor and it`s not showing full resolution, i need a driver for my macbook pro 13` (mid 2010) anyone????
I have a very strong suspicion that you are connecting your Macbook Pro to the VGA input on the monitor instead of the HDMI.
Your Macbook Pro uses the Mini Displayport connection type. Are you using a Mini Displayport to HDMI adapter? If not, purchase one and that will resolve your issue.
If you are already using a Mini Displayport to HDMI adapter, make sure your resolution is set to the maximum (1920x1080 according to Samsung's website) in Apple Menu > System Preferences > Displays > Display.
If available, select the 'Best for Display' option which should automatically set the maximum resolution for the display. If not, select 'Scaled' and choose 1920x1080.
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Won't display 1920x1080
I think you could have loaded the driver for a different model with 16:10 aspect ratio. Uninstall that driver.
Can you connect using the DVI port - get a DVI cable if your computer has a DVI port. If your computer has HDMI get a HDMI-DVI cable. DVI port will display max resolution - even without driver.
My macbook shows a qeustion mark when turned on
Your Mac cannot find your hardrive.
Boot your Mac from the install disk and reply with findings.
Philips 170B2 monitor - shows No Video Input when connected to 2011 macbook air. Cannot seem to find drivers online for mac and mac cannot detect the display.
It's nothing wrong with your monitor. Did you enable the VGA port of macbook?
I'm not sure about the key combination, but try F2 or F4 with Function/options key.
Using a Sony Bravia HDTV as a monitor for a Macbook Air
Hey RHSully,
In addition to connecting your Macbook to the TV, you may also need to adjust the video output signal coming from the computer itself. Several of the TV's in Sony's Bravia model line should include a list of the optimal settings for each screen resolution within the owner's manual, but you may need to search through Sony's online support site if you can't find this list for your specific model.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
