You can try removing the lens and putting it back again but if its still giving you the error message, you need to have the camera repaired by a technician.
i have the same problem..only it seems mine has been caused by a piece of plastic off my lens somehow falling behind the shutter and impeding its use.I wouldn't recommend you poking around the shutter but you could remove the lens to have a look if the optics is damaged.Bringing it to an authorized dealer might be the best way to go !
If you can dare servicing youself You can open bottom cover of and turn a little red wheel manually. try pressing the release button now and will start working. If you have this problem re-accuring, then get it checked wih professional.
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon. olly
I had the same error message, the camera is less then a year old, however, I was taking up to 800 pictires every weekend of my kids soccer games, then a 6 month trip to the Pursian Gulf, that is when it started, I got back home, took it right in, and one year later after a few visits and calls trying to find out where my camera was, I finally got an answer back, they said I needed a new shutter which will cost $300, They said I should just by a new body for $400. What Nikon does is set that error message to pop up at about 35000 shutter releases, and you can't do a thing about it, once they hooked my camera up to thier system the said I had over 36000 shutter releases, where the average person takes 10000 a year and they want you to replace the body every 3 years....so before buying any camera, always check out how many shutter releases you can get when you buy a camera
