I was sewing, heard a noise and now my machine only runs backward. I have had this Janome Model 2139N for 6 years. I have cleaned the Hook Race Unit and the Feed Dog. This is the only 2 items for "Care of my Machine" I have pushed the reverse button many times to no avail. Anyone know how to fix my problem?? Donna
SOURCE: Backward sewing machine
that sounds like the button is stuck. You may need to get it looked at.
SOURCE: sewing machine only sews backwards
Make sure that the machine is in straight stitch forward and the stitch length is the highest level that it can go. If that doesn't make it go forward, you will have to use the old hair dryer trick. Take the top lid of the machine off and heat the inside with a heated hairdryer. Work the stitch length and the reverse until it frees up.
SOURCE: I can't drop feed dog on my Husqvarna viking 230
It sounds like maybe you have it set up to make button holes.
SOURCE: sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
