I bought five Panasonic KX-T7730X phones. The business i work for has a Panasonic KX-TD1232 system. I unpack all phones and tried it on different extensions and won't work. there isn't ant pulse....
A TD system is a DIGITAL phone system and the 7730 phones are ANALOG. I don't know what X means, but I guess they're not from the US :-). Anyway, the ANALOG phones need 4 wires to work, instead of the 2 that the digital phones have. If your installer was lazy and didn't cross-connect 4 wires at the frame or put in 4 bridge clips on each jumper, then you don't have a voice path. Or, XDP is turned on and you'll have a bit of a problem.
If you have an IM and a PM for the TD system, you can find the wiring diagram and the instructions to read the XDP status. Quick answer is the first 2 of every 3 pairs will run to your phone. If you start with a digital phone in the port first, turn on XDP and plug a single line set into the XDP port, you will get dial tone (may have to dial 390 or 391 to enable/disable the XDP twinning) and that dial done will be different from the digital phone. If you don't get dial tone, your first pair wiring is missing. Fix that, turn off XDP and you 77xx series phone will now work in the port.
Carl
I have a panasonic kx-TG2432 phone I get no dail tone and
it just rings and rings if some one calls me but I don't hear the ring.
Help
Thanks
[email protected]
Is This Your Only Phone? Will Other Phones In The House Ring When This One Is Unplugged. Have You Disconnected The Phones Power Supply From The Wall?
