Heat stopped working on window unit. Are there replacaable strips?
SOURCE: window unit will not power up
You need to check for voltage to the display. Just knowing the plug is working doesn't tell you that the electronics are getting power. It is possible that the power cord is bad. Once you have tested the unit and the unit is actually getting power to the display, then it's probably the control board in this unit.
SOURCE: I have frigidare heat pump system. When turn on
Could be a couple of things...
The t-stat is wired wrong or the
reversing valve is stuck or the coil went bad...
heatman101
SOURCE: How many BTU's is the output from a Frigidare
The BTU output is 10,000
And here is a link to the online PDF owners manual from the fridgidaire website http://manuals.frigidaire.com/prodinfo_pdf/Edison/220202d019en.pdf
SOURCE: I HAVE A WINDOW HEAT/COLL
Change thermostat to heat mode. May be you're keeping in cool mode.
