20 Most Recent Frigidaire FAH106N1 Wall/Window Air Conditioner Questions & Answers
Good Morning Marty, thank you for allowing me to assist you. Here are a few simple troubleshooting tips that may help you resolve this issue:
· First, confirm that the unit has power to it.
· Check the power cord connection to the wall outlet is secure.
· Make sure that the house circuit breaker has not tripped.
· Try testing the air conditioner again. Make sure the unit is turned off, Press the TEST button, you will notice a clicking noise as the BUTTON pops out. Then press the RESET button. Again, you will notice a click as the button engages, now turn unit on. If the LCDI plug does not reset the cord may be damaged.
· The "Cool" circuit has an automatic 3-minute compressor time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. And the fan will continue to run during this time.
· If the unit has been turned off and on rapidly or if the thermostat was changed to a lower number and then immediately turned back to a higher number the compressor may not start. You must turn the unit off and wait a minimum of 3 minutes for the unit to equalize before restarting.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Frigidaire... | Answered on Jul 25, 2018
Is it a clicking or banging sound? The fan is most likely not kicking up the moisture to cool the evap coil off enough in the unit so you might here more noise for a little while. Monitor it and let me know if anything changes.
Frigidaire... | Answered on Aug 05, 2014
Good Afternoon Friend, thank you for your post!
I know you would are seeking information on how to turn off the timer on your Frigidaire air conditioner. In order to provide you the correct instructions, I would need your model number please. The serial tag, which lists your model number, is typically located behind the front grill by the air outlet or on the side of the cabinet. Other possible locations are on the front edge of the chassis base or behind the dial plate of the control panel. Thank you! - Z
Frigidaire... | Answered on Jul 17, 2014
Good Morning Friend,
I understand you want to know if a bad thermostat could be causing your Frigidaire air conditioner, model# FAH106N1, to be pulling too much voltage. There could be a possibility that a bad thermostat would cause your appliance to pull too much voltage. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able diagnose your air conditioner, and determine why it is pulling too much voltage. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 03, 2014
I understand that the compressor is loud on your Frigidaire air conditioner, model# FAH106N1. Today's high efficient compressors may have a high pitched chatter during the cooling cycle. This is just the way they were designed. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Frigidaire... | Answered on Jun 23, 2014
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Frigidaire... | Answered on Feb 25, 2014
Check for power at the plug in, if it's got power take it back under warranty.
Frigidaire... | Answered on Aug 19, 2013
Hi Britney, thank you for your question! This particular part is commonly replaced or repaired by experienced service technicians. If your appliance is still in warranty, you may want to check with the manufacturer to determine if there are any professionals in your area who will not only be able to ensure this is the appropriate fix, but may actually save you some cost and to prevent future issues.
Frigidaire... | Answered on Aug 08, 2013
Hi chip faust - When was the last time the filter was clean? Restricted air flow from dirty air filter can caused air conditioner to turn on and off rapidly. Make sure there is nothing blocking the airflow to the unit like drapes, blinds, furniture, etc which could restrict air distribution. When was the last time you cleaned the outside condenser coils? Confirm that the condenser coil is clean and not restricted by any trees, bushes, etc. Verify that the plug is not damaged and try resetting the unit. If any of these suggestions prove to be ineffective, then the unit could possibly have faulty PC power board, faulty compressor or power supply. Connect with a professional to accurately pinpoint any potentially more serious issues.
Frigidaire... | Answered on Jan 24, 2013
There are no heating strips within this unit. This unit has a heater part 5304476390 that you would need to replaced upon a diagnosis.
Frigidaire... | Answered on Dec 26, 2012
That is the temperature setting I would believe - meaning not the ?F setting but on a level of say 1-10 scale.
Frigidaire... | Answered on Aug 10, 2012
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Frigidaire... | Answered on Aug 06, 2012
Frigidaire FAH106N1 Wall/Window Air Conditioner Logo
56 questions posted
Top Frigidaire Heating & Cooling Experts
Donni Steen
Bill Long
Pete Norton
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Heating & Cooling
Most Popular Question
frigidaire fra18emu2 unit power
  • Heating & Cooling
