Dryers Logo
John Posted on Dec 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freezer works but the fridge area is not cool
My tenant's Kenmore 253.64802400 freezer is working but the fridge area is not staying cool.
Dan Webster
Level 3:
  • Dryers Master 8,221 Answers
  • Posted on Dec 21, 2012
Dan Webster
Dryers Master
Level 3:
Answers
8221
Questions
5
Helped
2381142
Points
25840
Remove the bottom plastic liner on the freezer and look midways ont the backside for the hole where the drain is. If it has a slabe of ice over it unplug the freezer and let it thaw out. This will take a day or 2 to fix so have the food transfered elsewhere. After thaw out clear the drain. Remove the rear panel and check the fan operation. At that point if the fan is operating you can put the panels back on and wsee if clearing the drain is the problem. If it happens again in a few weeks then either the heater is bad or the defrost thermostat is bad. When either one of these go out the timer still goes into defrost but the heat does not. So what water dribbles down in them 21 minutes tends to pool up and freeze over. The evaporator gets clogged . The refrigerator has a blizzard up in the freezer and nothing happening below even though the fan is blowing full blast shaboom!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
5 Related Answers
Anonymous
  • 833 Answers
  • Posted on Jan 16, 2008
SOURCE: Refrigerator
It sounds like you found it. Change the defrost timer.
Anonymous
  • 56 Answers
  • Posted on Nov 05, 2009
SOURCE: Fridge compartment of westinghouse bj433v-r is not
The freezer control on most units is just a door that you open or close to let more or less air into refirig from freezer. The higher the setting, the less air to the frig side.
If frost build-up on freezer side, then you have a defrost problem. Too much frost build-up on evaporator is blocking air flow to refrig.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Nov 16, 2009
SOURCE: fan is not turning (fridge and freezer not
If the fan is not working, you need to check to see if the fan is getting an electric feed to it, if not, then prob is elsewhere.
If it is, then fan is probably faulty, and would need replacing.
Please rate my comments.
Thanks.
Anonymous
  • 5 Answers
  • Posted on Dec 02, 2009
SOURCE: GE GSS25QGTA Side by side fridge not cooling, no
did you plug the fridge in and connect and turn the water pipes leading from the fridge to an outlet and water outlet, if you didn't you should
Anonymous
  • 180 Answers
  • Posted on Dec 04, 2009
SOURCE: My whirlpool ed22pw fridge/freezer is on coolest
It is possible that your refrigerator is not defrosting.  If the evaporator at the back of the fridge is ices over the fridge cannot circulate air, and will get warmer.  It could also be the evaporator fan, but more likely the defrost. You may have to take off the back panel to get to the evaporator coil.  If it is frozen over melt the ice, set the controls to center, and replace the defrost heater and defrost thermostat.
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • fan is working as you posted but is the air drawn from the freezer, better still, is the air forced/vented into the fridge?
  • could you please check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
My fridge is not staying cool. The freezer is nice and cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
I have a fridge that was made in 1995 that the fridge stays warm freezer works fine I also can not fine a model @ that I can read
heatman101
My kenmore fridge is not working, the freezer works fine but the bottom will not cool. the fan is working but not blowing out air in the bottom
heatman101
Kenmore Refrigerator 75509 double door top, bottom freezer. Freezer is working, but the refrigerator is not cooling
heatman101
1helpful
2answers
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
2answers
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Top Dryers Experts
john h
