How to stop WB27K5040 from beeping F1 error code
Unfortunately, the F1 error means that either the touch pad has a short or the "clock" (electronic control unit) has failed. Sometimes the wire between the touch pad and the clock fails. To test for the exact problem, you would need to unplug the range and access the clock from the back of the range. Unplug the touch pad from the clock. Then plug in the range again. If the error does not recur, the touch pad is bad. If the F1 error and beeping repeat, the clock is bad.
GE sold the clock and touch pad as a single unit for the WB27K5040. Since this is an older model range, the replacement is not in stock. There are some places that offer to repair the clock. You'll need to remove the part (or get a service person to do it) and send it in. Your range will be unavailable for some weeks while this is attempted. Otherwise, you should replace the range when the issue becomes too frustrating.
I hope this helps.
