20 Most Recent Neff B1421 Electric Single Oven Questions & Answers
3answers
Hi our NEFF B1451 oven has stopped working
It is most likely that the heating element has failed but there is the outside possibility it could be a faulty oven temperature sensor.
8/28/2022 9:56:56 AM • Neff B1421... • Answered on Aug 28, 2022
3answers
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
11/22/2017 2:19:51 PM • Neff B1421... • Answered on Nov 22, 2017
Oven is beeping and showing f1
Hello Charlie,The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
11/10/2017 3:46:51 AM • Neff B1421... • Answered on Nov 10, 2017
Neff series 1 oven
press the two arrow buttons in at the same time as turning the pop out knob
7/14/2017 6:32:41 PM • Neff B1421... • Answered on Jul 14, 2017
Power supply
it doesnt come with a cable it has to have its own 25 amp cable from your consumer unit or previous oven installation.
3/4/2017 7:44:56 PM • Neff B1421... • Answered on Mar 04, 2017
I can't remove the backplate off my Neff B1421 oven
its a tamper proof screw at torx 20 size.dont undo with a phillips tool will ruin the heads and never get them out.
3/4/2017 7:33:18 PM • Neff B1421... • Answered on Mar 04, 2017
Neff oven door gets hot
cooling ventilator fan has failed or jammed with grease this is not the fan at the back of the oven!
3/4/2017 7:27:40 PM • Neff B1421... • Answered on Mar 04, 2017
0answers
How do I unlock it
Unplug it and unlock
7/10/2015 5:10:02 PM • Neff B1421... • Answered on Jul 10, 2015
Why does the thermostat swtch off but the oven is not hot?
because its gone, or the connection to the ovens PCD board has been lost.
12/12/2014 10:23:25 PM • Neff B1421... • Answered on Dec 12, 2014
My neff oven error -5-. How do i turn this off?
I also had an error 5 on my Neff B1691 cooker. This indicates that a child lock has been set. To unlock you just push and hold the central control button in for about 7-8 seconds. Do the same again to set the lock again...
10/28/2014 7:26:01 PM • Neff B1421... • Answered on Oct 28, 2014
Leaking from freezer and fridge
Hang on, this is posted in Electric oven category but the freezer is leaking? Which query is it we can help with?
10/7/2014 8:23:50 AM • Neff B1421... • Answered on Oct 07, 2014
Removal of interior oven light
Most require a simple 1/4" nut driver to remove 2 screws that hold the glass housing over the bulb. Then just unscrew the bulb and install new one.
9/21/2014 4:40:22 PM • Neff B1421... • Answered on Sep 21, 2014
0answers
0answers
Neff B1421 Electric Single Oven Logo
161 questions posted
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
john h
Are you a Neff Oven Expert? Answer questions, earn points and help others
View Most Popular
Neff Ovens
  • Neff Ovens
Most Popular Question
neff oven error 5 turn off
  • Ovens
